mmm-five wrote: ↑Tue Oct 20, 2020 2:19 pm
Beemingallover wrote: ↑Tue Oct 20, 2020 2:13 pm
Yep, different characteristics then between them. So recommendations from coupe drivers on suspension may not relate to the roadie.
But the recommendation to get 'adjustable' suspension is valid, as the same suspension can be used on either car - as you can adjust it to your, individual case - be that the car, the road manners, the track manners, etc.
Otherwise, what suits a car with a 60kg driver would be completely unusable on a car with a 90kg driver, or a car where the standard electric seats have been replaced with carbon buckets
Accepted.
Back in the 1980s (remember those years?) I decided to "upgrade" from a series of Capri 3.0 and 2.8i to an Opel Monza. Lovely motor, the Opel, felt well engineered and solid, 5 bearing main crank, silky smooth straight 6 pot compared with the agri Ford V6. However, did it wallow in corners, after awhile I had fitted adj Konis. Stiffened it up alright but it felt odd, nervy. If anything it was retrograde to fit the Konis. Then Opel brought out an updated Monza GSE (1985?) with firmed up suspension and recaros. I traded in. The Monza GSE then was a very good "drivers" car, handled as it should have done in earlier models.
So, I'm wary of junking oem stuff.
