OEM suspension
- Beemingallover
OEM suspension
I have a ZMR on the original suspension set up and it seems fine, apart from harshness and wobble on some rough tarmac roads, so why do people replace OEM with other set ups?
Z4MR 2006 Interlargos Blue/Sepang Bronze SUMMER
E92 M3 coupe manual 2009 Silverstone Blue WINTER
M635Csi 1986 manual Lachs silver. GONE.
OEM suspension
Because it's harsh and jumps all over the place on rough roads.
- Beemingallover
OEM suspension
So the alternative would be a softer set up but doesn't it lose the sharpness and feel. I find that on smooth tarmac on Continental back roads the present set up superb, pin sharp placement through corners, accurate steering feel. I'll forgive the rough road ride for that.
With the alternatives, say Bilstein, would I lose that smooth tarmac sharpness. And if alternatives are better why did BMW set the car up the way it is.
BTW I run on Michelin PS4 shod 18".
OEM suspension
I think the reason people move away from oem is because the original sach dampeners are only available from bmw and they are expensive. The bilstein’s b6 shocks are an up grade on oem and compare favourably with regards to price. I have driven both and both ride and handling are improved with the b6.
2nd gear sideways
- GJ1
OEM suspension
I had a similar post. My car runs on m-sport suspension and I was wondering whether to stick with OEM or go over to Bilstein. I am currently favouring replacing with OEM shocks but may buy (slightly) shorter springs.
viewtopic.php?f=2&t=125072
07 Z4C 3.0si sport sapphire black
- Jembo
OEM suspension
Should you go Bilstein B12 pro kit, the rear Eibach springs are softer & have 90% cured the skipping mmm-five mentioned above on my ride.
However, found the front Eibachs too harsh for U.K. roads, so following a recommendation reverted to stock springs with Bilsteins
Lifer 54
Lifer 54
OEM suspension
Not softer, just more controlled & compliant. So it absorbs some of the bumps without being squishy, and doesn't act as Buckeroo.Beemingallover wrote: ↑Wed Oct 14, 2020 4:09 pmSo the alternative would be a softer set up but doesn't it lose the sharpness and feel. I find that on smooth tarmac on Continental back roads the present set up superb, pin sharp placement through corners, accurate steering feel. I'll forgive the rough road ride for that.
You'll find plenty of owners on here who have replaced OE stuff with decent kits from KW and Bilstein, and the road manners improve significantly on the softer bump/rebound settings, whilst allowing them to crank it up for tracks.
Mine is on Bilstein B16 PSS10, and is run at 3-4 for the road, and 8-10 for the track.
OEM suspension
I run KW V3’s after running OEM up until recently - if funds allow it is worth investigating. My car now feels completely transformed and far more compliant in all conditions.
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- Argenta
OEM suspension
I went from OEM to Eibach Pro springs (more compliant and comfortable on motorways) to KWV3 (in softest setting: even more comfortable and also more control. Needless to say prob outstanding on track too.)
- Beemingallover
OEM suspension
Thanks guys for the inputs. Useful info.
- wspohn
OEM suspension
I will be going to BC Racing when I need to change the shocks. They have worked very well for me on other cars.
Vancouver BC, Canada
2007 Z4MC
2009 Solstice GXP coupe
1962 MGA Coupe
1956 MGA (rebody+re-engined)
1958 MGA Twin Cam race car
1972 Jensen Interceptor
2007 Z4MC
1962 MGA Coupe
- R60BBA
OEM suspension
This ^
A good quality set of coilovers (eg KW) will ride better than OE suspension.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- Beemingallover
OEM suspension
How much would a set of KWs cost?
- BMWZ4MC
OEM suspension
£2 - 2.5k dependent on specific set up
S2000 GT - gone
- R60BBA
OEM suspension
That’s crazy because I paid £1,050 for my V2s which were bought brand new from a KW supplier.
Shame they only offer V3s and Clubsports for you guy’s platform.
For £2,000 I would be tempted to go Öhlins.
