Z4M Crank Rod Bearing Shells
I’m getting mine done soon - are King bearings and ARP bolts the go to decision?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- AndyBeech
Got them in mine and never heard of any issues. Hack Engineering and many other specialists use this solution so good enough for me.Simon 3.2M wrote: ↑Mon Sep 14, 2020 4:34 pm I’m getting mine done soon - are King bearings and ARP bolts the gold to decision?
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
It is what the engine builders I talked to recommended and are fitted to my engineSimon 3.2M wrote: ↑Mon Sep 14, 2020 4:34 pm I’m getting mine done soon - are King bearings and ARP bolts the gold to decision?
Lymm engine components sell both and a gasket set for the work required.
- Mr Tidy
Ross (Bowser) recommended ACL shells, so they are what I have.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Kings and ARP’s it is then
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- DSGRNMCM
So here are the old shells from my car. It is on 90k, these are AP Racing shells, so I'm assuming the second set.
Do you have to "run them in" and do you have to do an oil change after X miles as a new component has been fitted to the engine?
I'm no engineer, but they look "worn" to me, not sure what happens when they are "spun" I assume they break down and the debris causes damage to the engine?Do you have to "run them in" and do you have to do an oil change after X miles as a new component has been fitted to the engine?
E86 Z4m Coupe - Titan Silver, Stubby, Sun protection, Eibach springs, LED interior lights, CDV delete, Badge delete, Pipercross, Exhaust bypass
F11 520d, E46 328i, E91 320d, F21 120d, E46 318ti
Mk VI GTD DSG (Daily Hack)
- AndyBeech
Damn they look pretty ruined to me, especially for a 2nd set at a mileage when most people are only replacing the originals! Did they inspect the crank for damage before they put it back together? You'd known if it had spun as you'd get a knocking sound which is the piston conrod banging on the crankshaft journal if a bearing had failed, though I would say you were pretty close to that point with a few of those bearings...(the lighting on the picture might be making it look worse but still).DSGRNMCM wrote: ↑Fri Sep 18, 2020 6:07 pm So here are the old shells from my car. It is on 90k, these are AP Racing shells, so I'm assuming the second set.
99% sure AP Racing have nothing to do with engine bearings so not sure who told you they were made by them. King Racing I suspect is more likely if they have been replaced before.
Running in is a multiple answer depends who you ask kind of question. IMO, in theory no as there is nothing to 'bed' in as such. On the other hand, it doesn't hurt to take it easy for a few hundred miles / 1000 max just so if there's been any issues with the installation you'll be at lower revs and less likely to do damage. Plus any small containments that got in the oil / engine whilst apart and the assembly lube that was used can be flushed out with an oil change after that amount of mileage is done just for piece of mind.
After my rod bearing change and doing myself, I choose to run mine in a no real need to other than if you suffer infantile mortality failure it would be with lower load and revs and a paranoid sense of hearing.
I warmed the engine up each time I use the car let the oil pressure drop down to 50ish psi then start to drive the car watching the oil temp water comes up quickly oil slower. In the running in phase I used 3500 as a limit and light load on the engine after 1200 miles I changed the oil filter then at 2000 miles oil and filter. Oil will be changed this winter after around 6000 miles use using all of the engines range
This is what I did it makes sense to me
Can you take another picture of the bearing shells with a piece of white paper next to them for the colour corection.
They look in a bad way.
They look absolutely f***ed!! I’d say there were very close to spinning so you have changed just in time. What is of concern is that they are the second set!DSGRNMCM wrote: ↑Fri Sep 18, 2020 6:07 pm So here are the old shells from my car. It is on 90k, these are AP Racing shells, so I'm assuming the second set.
I’m getting mine done on Wednesday as I’ve no record of them being done.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
OnlineR60BBA
I doubt those are AP Racing shells...what makes you think that?DSGRNMCM wrote: ↑Fri Sep 18, 2020 6:07 pm So here are the old shells from my car. It is on 90k, these are AP Racing shells, so I'm assuming the second set.
AP Racing make big brake kits and clutches/pedal boxes - they don’t make con-rod bearing shells.
Those are some of the worst I’ve seen. You are lucky that they did not spin.
As per others what was the condition of your crankshaft? Was there any scoring?
You also mentioned they were a second set, how many miles have the shells covered?
In regards to your question of running-in, BMW recommend the engine should be run-in again after a rod bearing service but an oil change is not required.
Nevertheless it is good practice to drop the oil and can offer peace of mind at an insignificant cost...
Current: 2002 E46 M3
Current: 2004 R53 Cooper S
Current: 2005 997 Carrera S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- DSGRNMCM
Hi R60BBA,
The second set were not documented in the SH, so I can not tell the age / mileage. The garage who carried out the work informed me of the brand. I'm just happy it has been done, even though the local garages advised against it, and suggested oil analysis.
Results have come back from the oil samples. Both are taken at around 4000 miles. Car is at 50k miles.
If anything lead, copper and iron content has all been lower. The absolute values are not very high, so fingers crossed.
Previous Oil Sample: Latest Oil Sample:
Interlagos Blue Z4MC
My car has 26k on the clock with very minimal mileage done last few years and owners.
Do you think I should get mine done due to age and not knowing how the owners prior to the last few used the car?
Also has anyone used Redish for this work as they are my local and look after my other cars.
Abid
Abid
Z3M S54 Black
Z4M Black/Black
E39 M5 LMB
E61 M5 Touring SG
F10 M5 30 Jahre
E90 M3 Black/Black
E31 840CI Sport
Z4M Black/Black
E39 M5 LMB
E61 M5 Touring SG
F10 M5 30 Jahre
E90 M3 Black/Black
E31 840CI Sport
- z4mcza
Here are my bearing shells after 57,000 miles. Along very similar motivations to Mr Tidy, I decided to book my car in with RBM Hampshire (highly recommended btw). Turns out that at least one of the previous 9 owners of my car lacked mechanical sympathy
- bearingshells57k
- bearingshells.jpeg (319.8 KiB) Viewed 1087 times
2007 Sapphire black BMW Z4 ///M Coupe - ~57,000 miles
2021 Stormtrooper BMW i3s 120Ah - ~13,000 miles
