Ride height
- Mr Tidy
Ride height
Good luck with that!
To be fair mine are Reps, but were on the car when I bought it so I didn't have to resist that urge!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Penelope
Ride height
The only way I can stop myself ordering some 19" Riva DTMs is to constantly wheel off clean my MV2s. They look stunning when shiny but I go off them as they get dusty...
- IMG_2679.jpeg (206.25 KiB) Viewed 1086 times
2008 BMW Z4 MSport 3.0 Si Coupe in Stratus Grey with Red New England Extended Leather Upholstery. Purchased 14 December 2019 via the Forum with just 25k miles.
- Mr Tidy
Ride height
I know exactly what you mean!
My 1st Coupe came with badly scuffed MV2s so I got them refurbed, but they were a real PITA to keep clean with those narrow gaps between the spokes!
Thankfully my 2nd had decent 108s which were much easier to clean, but then I swapped them for 295s that were even better.
I think the CSL Reps might be a bit more involved to clean, but they look so good I just might make the effort!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Onlinewspohn
Ride height
FWIW, the BC Racing shocks I have on my Solstice have a range that brackets the stock ride height, so unlike some aftermarket units, they do allow you to set height at factory spec or even higher. That's a wise choice, BTW - too many owners want that low and mean look and end up scraping their front bodywork on steep driveways and speed bumps, and possibly affecting the handling in an undesirable way as you mentioned.
Whenever I do change the shocks on my Z4M coupe, I intend to use the BC Racing units (not in a great rush as it only has around 37K (miles) on it at the moment and the factory shocks are still in excellent shape.
Vancouver BC, Canada
2007 Z4MC
2009 Solstice GXP coupe
1962 MGA Coupe
1956 MGA (rebody+re-engined)
1958 MGA Twin Cam race car
1972 Jensen Interceptor
2007 Z4MC
1962 MGA Coupe
Ride height
Mine is on stock suspension so I’ll measure up later and post my findings.
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Ride height
Hells bells that looks good with Imola and grey 19’s Simon....liking that a LOT..!Simon 3.2M wrote: ↑Fri Apr 17, 2020 8:08 am Mine is on stock suspension so I’ll measure up later and post my findings.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Ride height
Thanks for the very kind comments John - I’m absolutely smitten with herjohn-e89 wrote: ↑Fri Apr 17, 2020 10:34 amHells bells that looks good with Imola and grey 19’s Simon....liking that a LOT..!Simon 3.2M wrote: ↑Fri Apr 17, 2020 8:08 am Mine is on stock suspension so I’ll measure up later and post my findings.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Ride height
Rear - centre of the wheel to bottom of the wheel arch 358mm and 368 for the front. Hope that helps.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Onlinewspohn
Ride height
I love both the Imola red (I painted my rebodied 56 MG in that colour) and the blue. Of course I have a silver gray Z4M, but the M coupes are a bit thin on the ground not to take what you can get when you can get it.
2007 Z4MC
1962 MGA Coupe
2007 Z4MC
1962 MGA Coupe
- srhutch
- Moderator
Ride height
This will give an indication of difference between OEM and H&R springs.
- RedUn
Ride height
Shows the rear wheel dish nicely that pic
- srhutch
- Moderator
Ride height
Got them adjusted to OEM spec and it looks great. It was 17mm lower at front and 15mm rear!
Maybe a mm or two lower at the front would be best but that can wait for corner weighting and alignment. Rides very well on these coilovers.
Onlinewspohn
Ride height
Just a comment on ride heights.
Racers set height to get maximum handling adhesion and they pay attention to things that affect that like bump steer. Street drivers usually adjust height so that (to them, at least) it 'looks cool', and damn the consequences to good handling. If that results in dragging across speed bumps or objectionable bump steer, they tend to ignore it.
There also seems to be a commonly held misconception that lower is automatically better as far as handling. I have adjusted the height on one of my race cars by almost an inch and the lap times were the same (within 0.5 seconds a lap) but the toe change at full bump was improved.
I tend to set my street cars at factory height and even at that, you have to watch out for bumps. It has a ground clearance of 5". The Z4M has a clearance (IIRC) of just over 4" - to the shield under the engine i believe. Lower = probably not a really good idea. And no good reason - the black car in the post above mine looks perfect!
2007 Z4MC
1962 MGA Coupe
2007 Z4MC
1962 MGA Coupe
