Mr Tidy's MC Thread - 4 Years On!
- MrPT
Mr Tidy's MC Thread - A Bumpy Ride just now!
Aha, result. That actually looks pretty close to stock.
Found this pic from the TMS site of a similar/same H&R perch -
I think they are fitted right they were just lowwwwww.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Mr Tidy
Yes, those are the ones we found. The only thing you could see below the lower wishbone was the hex head and most of the thread!
Now it's just the hex head and the circlip.
I'm hoping to keep them fitted now it's riding higher, as the previous owner paid over £1,000 for the full kit including dampers last September so it's virtually new!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MrPT
Drop it back down, Iain, it looked awesome. Never mind your spinal column.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Mr Tidy
It wasn't my spinal column I was worried about - it doesn't ride any softer when it's higher!
It was the front undertray, wheel-arch liners and exhaust I wanted to save.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MrPT
Mr Tidy's MC Thread - A Less Bumpy Ride now!
Did you get there in time? My undertray took a bit of a beating when lowered as well - had to patch it up.
If the rear is adjustable via an allen wrench from below, then that's quite a neat design. Mine have an adjustable top perch but it won't budge with the spring under load so you need to unbolt the rear control arm (!) to change height.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Mr Tidy
No and yes! The front undertray has a chunk missing, but although the front arch liners are rubbed I got them before they went right through!MrPT wrote: ↑Wed Feb 05, 2020 10:41 pm Did you get there in time? My undertray took a bit of a beating when lowered as well - had to patch it up.
It might be possible to adjust the rear with an allen wrench, but with the spring under load I'm not sure it would work. Ross popped the springs out to adjust them.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- LeeZ4MR
I was really shocked at the exhaust hanger missing.
It just shows that you never really know what is happening in areas that you can't easily see for sure.
Current...BMW F82 M4 Coupe 2018
370Z Roadster 2011
Merc GLE400d 2022
Caterham 7 2002
Previous...
640d 2012
330i 2006
Z4MR 2006
E92 M3 2009
X5 4.8iS 2004
TVR Cerbera 4.5
370Z Roadster 2011
Merc GLE400d 2022
Caterham 7 2002
Previous...
640d 2012
330i 2006
Z4MR 2006
E92 M3 2009
X5 4.8iS 2004
TVR Cerbera 4.5
- Mr Tidy
Yes, I was too! Why would you remove it?
Still the back-boxes are PowerFlow ones so at least they sound good - just need to stop one of them from falling off now!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Smartbear
Does it now clear the plethora of speed bumps in your area?
e85 3.0si sold
- RedUn
Normally if you jack it up its enough to adjust the spring platforms assuming the threads are fairly clean and lubed. More for future forum use as it's a bit late nowMr Tidy wrote: ↑Wed Feb 05, 2020 11:02 pmNo and yes! The front undertray has a chunk missing, but although the front arch liners are rubbed I got them before they went right through!MrPT wrote: ↑Wed Feb 05, 2020 10:41 pm Did you get there in time? My undertray took a bit of a beating when lowered as well - had to patch it up.
IMOLA Z4///MR
Are the wheels 18” or 19” ?
I have 19’s with Eibach and H&R springs only, I live in Romford Essex with plenty of speed bumps and only just about catch what I assume is the undertray on only the highest bumps.
- FF6DD33B-B53B-43AD-81CA-3FC9728B816A.jpeg (389.81 KiB) Viewed 1982 times
Current - Z4 MC, M3 CSL, S54 Z3MR, Z1.
- Mr Tidy
My wheels are 19s, and I got to test it over speed bumps for the first time today. There is a 20 mph limit with half a dozen bumps in the middle of my mate's village and it cleared them all in both directions, so it looks like the coil-overs will be staying on!
A bit off-topic but I'm sure Rob would be interested! I went round to see mate's latest motorbike acquisitions, a Honda TL125 we rode round his garden and a 1971 Yamaha YR5 that we both had a short ride on around where he lives. That took me back so many years to when I had my RD350. He's also bought a Yamaha Serow, but hasn't picked it up yet.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Mr Tidy
Well it's time for the next instalment!
I bought the headlamp washers "parabolica" was selling, and went to see Ross at RBM this morning.
I knew there were no diamond clips with them, and one of them had a broken clip that holds the diamond clip in place, and sure enough that's the one I needed. Still Ross managed to use the jet from my leaky one which had the clips intact and put a new seal on it. So after a bit of faffing around I didn't need the new one from BMW and can now have working washers all round! Although I think the fuse for the headlamp ones might be coming out soon.
But one of the clips on the cap has a bit missing, so now I need to get a new cap that'll need painting.
Anyway thanks to parabolica, and also to Ross.
In the unlikely event anyone has a spare headlamp washer cover lying around (ideally in silver grey) please let me know!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- bradz
Just unplug the 2nd pump on the washer bottle (Electrical Connection) and they will stop working and causes no faults.
I had to replace mine on my Z4C as the bodyshop snapped the tabs off!
Z4M Coupe, E92 M3, E46 M3 Track car
- Jembo
I just took the fuse out... & back in @ MOT time
Lifer 54
Lifer 54
