Oil service
Oil service
How much should I be paying for a BMW independent specialist for a an oil service? I have been quoted £472 which I think is way too much!
Z4///MC
Oil service
What exactly is done for the oil service as I do mine myself
Are all oils/fluids changed
Engine 6 to 7 ltrs of 10/60W oil a good brand time to change inc oil filter 30mins
Gear box oil 2ltrs max, time to change 30 mins needs to be on a ramp to make it easy
Diff oil this needs 1ltr of oil and a little tub of friction modifier, time to change 30 mins needs to be on a ramp to make it easy
Power steering fluid unlikely to be changed but may take 45 mins
Brake fluid change and bleed maybe an hour if on a ramp or axle stands and if the wheels are off or not, plus the fluid
3 hours at £60 per hour £180 plus the cost of the fluids search euro parts for the cost of these.
Oil service
And forgot to mention the previous owner paid £ 354 including MOT and vat the previous year with BMW. Hence my concerns! I have called BMW official dealer in Peterborough 3 times over two days and left messages with staff and they have still failed to call me back to get a price from them!
Z4///MC
Oil service
Sorry I edited my question out as I realised this is in the M section
- AndyBeech
Oil service
£150-£200 max for an independent (Poss less tbh). Literally engine oil and filter. No other fluids changed.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
Oil service
If it’s just an oil service then £150 max, buy the oil yourself from europcarparts and it’ll be even less. The dealer is taking the piss here.
Oil service
So £160
And you will have some oil left over for top ups if required.
- AndyBeech
Oil service
Personally I’d stick to Castrol oil and a Mahle filter.
5.5 to 6 litres max for an oil change.
Oil service
Andy
I was advised to use Mobil 1 by both Mr Vanos and Simon Thorpe, the comment about Castrol was it turns a bit sticky or waxy not the best decryption I know, but when I removed my front timing cover last weekend there was a stubben oil residue on the inside of the casing.
However I do not know what oil has been in the car before I got it so it is a bit of guess work as to what was used before and weather Mobil 1 would leave the same residue
Personal preference and choice............
- AndyBeech
Oil service
Fair enough, not heard of Simon Thorpe though.
I purely base it on Castrol is tried and tested since these cars were made and had no problems yet personally so no reason to change, though shorter intervals is clearly best whatever oil you use. Not to say Castrol is the best available though.
Oil service
That's not an 'oil service' though, that's more of an 'all fluids service'.PDJ wrote: ↑Wed Dec 11, 2019 6:58 pm What exactly is done for the oil service as I do mine myself
An oil service is simply the engine oil and oil filter. Diff & Gearbox are only scheduled to be done on Inspection II.
- R60BBA
Oil service
Oil service: £170-£200
Inspection I: £500
Inspection II: £700-£1,000
OP, who quoted you that price?
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- Chris_D
Oil service
Yeah op, name and shame please!
That’s takin the bleedin p!ss!
