Interesting, at risk of sounding stupid though how did you fix this?MrPT wrote: ↑Sun Dec 08, 2019 10:05 pmB00DF697-E662-4B1C-A1FD-C6142C00DEE4.jpegMrPT wrote: ↑Wed Dec 04, 2019 5:01 pm I should caveat the note re the rear springs - I don’t actually know whether the “thunk” is a genuine hard stop in the suspension or whether it’s just the coils becoming unbound on extension (and hammering the chassis). I suspect it’s the latter but need to do some experiments to find out.
Sorted! Went out today and smashed the sh!t out of every local pothole and humpback bridge. Now totally silent over everything.
There were actually a few, quieter “clinking” noises back there before that I’d assumed were the boot trim but must have been coil slap as they’re gone now. Happy days... I suspect they will go to full soft (bump) at the back without ever bottoming out now. The occasional “thunk” was just the coils unbinding.
Suspension Upgrade Advice
- AndyBeech
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
[/quote]
I've no clue about BCs but a twin tube damper is what you want for road manners
[/quote]
I think BCs are monotube, but empirically they perform very well for the price in my experience.
it might be worth checking out how this owner is finding his BCs after a few more months of use:
viewtopic.php?f=9&t=101724&start=45
[/quote]
- MrPT
Not stupid - I realise I didn’t actually say what it is.
It’s plastic cable tidy, the stuff used in offices, wrapped loosely around each rear spring. I saw the suggestion on another forum in relation to coil noise (slap) and wondered whether it would also stop the binding. It’s very cheap but hopefully it will still last a reasonably long time.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- RedUn
If that doesn't last you can buy genuine stuff, might or should last longer
IMOLA Z4///MR
- Argenta
Of course it's firmer than a 7-series but still softer than OEM.
- AndyBeech
Received the PSS10's.....one of the rear springs though has some of the coating missing exposing the metal, only a bit but would this be a problem later on with rust?
Waiting to hear from Bilstein on it but not sure what response to expect...
One of the adjuster knobs is a bit stiff moving from 9 to 10 compared to the other struts as well, again waiting on Bilstein to see what they say...probably ok but anyone else with PSS10's experienced this?
PSS10 by A W, on Flickr
I will be upgrading the ARB on my TT RS with some H&R arb's with the KW V3's soon. Not heard any mention of chaning the the arb's on this forum though. any thoughts ?
Monaco Blue Z4M Roadster & Solar Orange TT RS
- RedUn
That will rust in no time, get it sorted under warrantyAndyBeech wrote: ↑Fri Dec 13, 2019 10:09 pm Received the PSS10's.....one of the rear springs though has some of the coating missing exposing the metal, only a bit but would this be a problem later on with rust?
IMOLA Z4///MR
- RedUn
Running H&r bars on mine with KW CS, works really well! You need to beef up the front mounts though to be on the safe side
IMOLA Z4///MR
- BMWZ4MC
I would insist on a replacement for the spring and the damper too if it is significantly different from the others. You’ve bought new suspension from the manufacturer (or their distributor), you can expect new, undamaged parts. If they refuse, you have seven days from receipt to reject goods without giving any reason under the UK Distance Selling Regulations. Also, if you used a credit card, there is usually legal protection provided for you if it becomes unpleasant.AndyBeech wrote: ↑Fri Dec 13, 2019 10:09 pm Received the PSS10's.....one of the rear springs though has some of the coating missing exposing the metal, only a bit but would this be a problem later on with rust?
Edit - it seems the Consumer Contracts Regulations have replaced the UK Distance Selling Regulations since last I needed them, but the relevant rules still apply:
https://www.which.co.uk/consumer-rights ... egulations
S2000 GT - gone
- BMWZ4MC
I have H&R ARBs and KW Clubsports on my ///M. Fitting the ARBs required adjustable drop links, and I’m a little more limited as to wheel offsets with the KWs vs OEM, but the car corners absolutely flat and doesn’t pitch under braking or acceleration.
S2000 GT - gone
- AndyBeech
Cheers chaps. Is what I thought. Brought them through Demon Tweeks so will push for replacements. Think they said they have to go through Bilstein but hopefully they won't mess around....
Not entirely surprising I guess, dates of manufacture on the springs are 2016 for the fronts and 2014 for the rears so probably been sat around / chucked around a warehouse for all this time!
I'd not be accepting that spring.AndyBeech wrote: ↑Fri Dec 13, 2019 10:09 pm Received the PSS10's.....one of the rear springs though has some of the coating missing exposing the metal, only a bit but would this be a problem later on with rust?
The adjusters should only be 'stiff' between clicks, and then have almost no further movement after either 1 or 10.
- MrPT
No experience with the Bilsteins, but on the KWs the adjustment is stiffer right at the limits of adjustment, making it hard to tell where "0 clicks" open is vs "1 click".
I'd be tempted to live with those springs if they were purchased on their own as they will chip pretty quickly anyway, but if they've come as part of a package, don't take any chances. It could suggest abusive handling.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Yeddheng
Haha! When I got my KWs delivered they partially stuck out of the packaging and both top mounts were damaged. Got a new set a few weeks later.
Z4 MC 07 / A08 Silver grey / Black interior w Carbon leather / VT+RE mounts / 10.9 / cdv- / RPi / Cup2 / Arc-8 / Lugs / KW V3 / GC camber plates / Vorshlag RTAB limiters / Custom alignment / Aux / Stubby / Mud flaps /
My Z4MC
My Z4MC
