Not 100% on the M but its pretty easy on the 3.0si had it out in less than an hour
I used this method for my non m coupe https://www.instructables.com/id/BMW-Z4 ... e-removal/
No different.adam1985 wrote: ↑Thu Nov 07, 2019 11:13 amNot 100% on the M but its pretty easy on the 3.0si had it out in less than an hour
*just* what i was going to say
Or you can go for the more redneck approach of bleeding normally as best you can. Take it for a test drive and activate the abs pump by an emergency stop on gravel and it should have pumped the air out of the abs unit. Then bleed the brakes again as normal.
How does that work with a closed system. Why would the air move out of the ABS pump?adam1985 wrote: ↑Tue Dec 03, 2019 10:16 pmOr you can go for the more redneck approach of bleeding normally as best you can. Take it for a test drive and activate the abs pump by an emergency stop on gravel and it should have pumped the air out of the abs unit. Then bleed the brakes again as normal.
Not as good as INPA method but it doesn't need any special software.
MrPT wrote: ↑Tue Dec 03, 2019 8:39 pm Doubt it will be the fluid causing the sponginess. It’s more likely to be air in the system, i.e. they didn’t do a good job of bleeding.
Common oversights are not bleeding both sides of multi-pot calipers and not going through a thorough ABS bleed procedure when replacing the pump and/or fluid.
Good point, I'm not entirely sure i presume that the pressure exerted by the pump is sufficient to force the air out of the pump into the brake lines. Your right in a closed system without a loop it doesn't sound like it should work.
