Space saver
Space saver
Off on a European trip, does the E46 space saver fit on a standard M?
- AndyBeech
Space saver
Fit where? No spare tyre on a Z4. Best to just get the tyre goo stuff if the worst happens that’ll get you to a tyre shop
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
- kis
Space saver
E46 17” space saver only.
The 16 will be too small (for the front).
See here for more info viewtopic.php?f=49&t=107556
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- srhutch
- Moderator
Space saver
Will 17” clear the ///M’s callipers?kis wrote: ↑Fri Aug 16, 2019 9:46 pm E46 17” space saver only.
- Tinker15
Space saver
So when you have a puncture and put on the space saver where do you put the full size wheel?
Space saver
in the boot, passenger seat or roof (if you’ve got a coupe)
- Tinker15
Space saver
Right! Provided you have no passenger and a folding toothbrush for luggage.
- kis
Space saver
Does on an E46... so assumed it would on a E85/86? Does it not?srhutch wrote: ↑Fri Aug 16, 2019 10:10 pmWill 17” clear the ///M’s callipers?kis wrote: ↑Fri Aug 16, 2019 9:46 pm E46 17” space saver only.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Adam D
Space saver
Front brakes are larger and borrowed from the CSL. There isn’t much clearance with the stock 18”s.kis wrote: ↑Sat Aug 17, 2019 11:44 pmDoes on an E46... so assumed it would on a E85/86? Does it not?srhutch wrote: ↑Fri Aug 16, 2019 10:10 pmWill 17” clear the ///M’s callipers?kis wrote: ↑Fri Aug 16, 2019 9:46 pm E46 17” space saver only.
Silver Grey 2007 Z4MR which needs to be driven more
- exdos
Space saver
I bought a tyre plugger kit like this one ages ago: https://www.ebay.co.uk/itm/TUBELESS-TYR ... Sw9UlZj~LF
I've never needed it on my ZM but used it twice to fix punctures on my wife's Mini with runflats and the repairs lasted for the life of the tyres. Provided the puncture is caused by a nail or screw and on the main area of tread its very easy to do the fix with tyre still on the wheel and on the hub once you've identified the culprit's position.
You could then fill the tyre with the tyre gloop as "belts and braces".
