Need to get my Vanos looked at
Hi all,
I need to get my Vanos looked at as down on power.
I’m based near Oxford.
Have tried to get in touch with Dannagh at everything M3 but no response after weeks.
Any suggestions appreciated. Can’t believe how hard it is to spend my money!
Simon
Simon
- Jembo
I know people who travel much further than that to ETA Motorsport in Kent.Anothermidlifecrisis wrote: ↑Fri Jun 21, 2019 5:21 pm Hi all,
Simon
Bunch of true petrol heads who always have given me time.
Lifer 54
Lifer 54
- exdos
How do you know for sure that your car is down on power and how can you point the finger at the Vanos? What tests have you done?Anothermidlifecrisis wrote: ↑Fri Jun 21, 2019 5:21 pm I need to get my Vanos looked at as down on power.
Mr vanos travels to your location and fits reconditioned units. He’s got a good reputation.
Z4MC Interlagos Blue
Instagram: z4mcuk
Instagram: z4mcuk
Hi guys,
My engine light came on and then went off. It’s lumpy at low revs and is knowhere near as quick.
Mr Vanos has a bad review on here which put me off but maybe it was a one off?
I’ll check out these guys in Kent as I need a service also.
Thanks for your replies.
- exdos
You need to hook up to diagnostics to find the actual cause.Anothermidlifecrisis wrote: ↑Sat Jun 22, 2019 8:16 am
- Spaniarduk
Anothermidlifecrisis, like crustyclown777 saidcrustyclown777 wrote: ↑Sat Jun 22, 2019 7:47 am Mr vanos travels to your location and fits reconditioned units. He’s got a good reputation.
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- BMWZ4MC
OP, another excellent indy and ///M specialist much closer to you is CPC Performance Engineering in Amersham:
http://www.cpcpe.com/
S2000 GT - gone
- bradz
I'm a Huge fan of ETA the work they have done on my M3 was top notch!
I would however recommend to you Everything M3's hes had lots of great reviews and located in Banbury.
https://www.everythingm3s.co.uk/
https://www.facebook.com/Everything-M3s ... 713409262/
Z4M Coupe, E92 M3, E46 M3 Track car
best way to get Darragh is Facebook messenger via his everything m3/// page. He has just done mine highly recommended. May need a bit of perseverance as he is absolutely stacked with work most of the time. But I wouldn’t go anywhere else.Anothermidlifecrisis wrote: ↑Fri Jun 21, 2019 5:21 pm Hi all,
Simon
1st Z4 bought in 2009 - Sapphire Black, 2.0l Sport SOLD
2nd Z4 bought in 2013 - Midnight Blue, 2.0l Sport SOLD
3rd Z4 bought in 2019 - Sapphire Black Z4MR Imola Red Leather
Hi Michael,
That’s good to hear as I was beginning to take it personally! I can’t wait any longer so I took my car to DMWorkx and they advised that there is one fault on my Vanos on exhaust port. I’m getting my car to DMWorx who will do an insp 2 and whist it there Mr Vanos will come down and change Vanos. Will also get timing chain changed. Simon Just had new tyres so expensive month!
- Spaniarduk
I got mine replaced by Mr VANOS at my home address in Leicestershire during the weekend. While he was 'at it' he also checked the valve clearance (two shims needed replacing) and, surprise-surprise!!, the timing chain was stretched thus throwing the timing out and allowing for additional rattle. Steve (Mr. VANOS) replaced the timing chain, too. I was very surprised when he actually showed me the slack. Not crazy, but a slack that shouldn't be there anyway.Anothermidlifecrisis wrote: ↑Sat Jun 22, 2019 8:16 am Hi guys,
The engine now runs quieter in the overrun and with no torque surges below 3k rpm.
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Does he replace the timing chain tensioner as well as the timing chain, or does the tensioner never break on the S54 (mine did on an S38 M5). If there's not a lot of stretch, then the tensioner should take up a bit of the slack anyway.
You need Mark Purcell, Oxford based and a great rep. A few friends and I, all use him on our BMW's.
He's here: The Hangar Horton Road, Stanton St John, Oxford OX33 1AG. Ignore the other addresses you see online, they are old.
01865 711525
01865 711525
- ph001
The valve clearances need to be done in a controlled environment of 20'C. The tolerance on them is so tight that just an ambient temp change of 10'C is enough to push them from one end of the spec to the other. Unbelievable I know, but many repeated checks both first thing in the morning (about 7'C) compared to middle of afternoon (about 19'C) can make the difference between in spec and out of spec. Confirmed with many repeated measurements over 2 days using very high quality digital vernier calipers.Spaniarduk wrote: ↑Mon Sep 09, 2019 4:42 pm I got mine replaced by Mr VANOS at my home address in Leicestershire during the weekend. While he was 'at it' he also checked the valve clearance (two shims needed replacing)
