3 weeks in, Photos and list of jobs!
After pulling the trigger on the Z4M 3 weeks ago, I’ve been busy! Still a couple of things left to do, but so happy with the results so far!
To Do:
- new M badges (on their way, so expensive but needed)
- exhaust tips clean and polish, I just don’t have the right gear and I don’t think they’ve been done since new.
- new windscreen, a few chips and the top seal is going, but not super urgent.
- little worried about some mechanical clunking when depressing the clutch at slow speed... will have it looked at
- washer bottle leaking, no idea where the leak is so need to test and repair
Done
- Inspection 2 at Iridium in Hampshire (recommended) car “very clean” all shims good, seems a fine example! For 54,000 miles 06 plate
- learned what Shims are!!
- new Bonnet Badge
- full wheel refurb
- new tyres
- deep wash, (took 3 hours) including door jam degrease and re-dress
- hand polished with Motor Show polish
- zymol Carnuaba Wax
- bead maker paint protection
- megiuar’s quick detailer (just before photos)
- rubber redress & protection
- meguairs ultimate black on exterior trim
- full interior clean, vacuum, dust, wash & dress
- leather clean with the Furniture Clinic cleaning kit and dress & condition with colour match leather cream
- roof clean and prep with 303 convertible top care kit (took 3 cleans to get it clean
- install GROM BT3 after disconnecting CD Changer (could have happily killed someone at this point) also had to update the software to stop it giving track names as it forced the Nav screen up constantly very annoying!
- Ran USB socket and charging cable through behind ash tray trim (very neat)
- Brodit Pro clip & Mount
And that’s it! Photos below;
To Do:
Done
- new Bonnet Badge
- full wheel refurb
- new tyres
1st Z4 bought in 2009 - Sapphire Black, 2.0l Sport SOLD
2nd Z4 bought in 2013 - Midnight Blue, 2.0l Sport SOLD
3rd Z4 bought in 2019 - Sapphire Black Z4MR Imola Red Leather
Very smart, you need to sort your number plates though, don't want to get pulled
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Unnecessary? Habit from many years ago!
Looks really good. Lot of effort but it shows
E86 In sapphire black
- Mr Tidy
That looks lovely - you've been busy!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- JamieZ4C
That really is an epic list! Hats off to you, a gorgeous looking M
On the subject of number plates, I really can't see a good reason for owners going to the bother of hiding them
- buzyg
I believe that mechnical sound when depressing the clutch pedal is quite normal. Mine has always done it and I've heard others doing it as well.
Thanks this gives me some comfort; it almost sounds like it’s coming from the diff behind me... doesn’t sound “broken” or anything just wanted to check whether others had heard it. Thanks again.
- paddy wright
Lovely looking ///M
I was going to say the same as Polarbert Micheal, M’s are pretty clunky, especially when cold, compared to more modern cars but it’s normal, unless there is excessive play in the driveshaft. They can clunk a little causing concern but again it’s normal for these, I think you’d really notice it if there was a problem with the diff, for example on every gear change, if it’s not doing that then it sounds perfectly normal.MichaelPorter80 wrote: ↑Fri Jun 14, 2019 9:24 amThanks this gives me some comfort; it almost sounds like it’s coming from the diff behind me... doesn’t sound “broken” or anything just wanted to check whether others had heard it. Thanks again.
Happy M’ing....
Edit: Said ‘normal’ far too many times in that post......damnit.....did it again....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- srhutch
- Moderator
I did it for a while when this started happening.
viewtopic.php?f=5&t=71809&hilit=cloned+srhutch#p1052990
Maybe I’ll start doing it again then!! And thanks everyone for the advice.srhutch wrote: ↑Fri Jun 14, 2019 11:48 amI did it for a while when this started happening.
- Mr Tidy
I was lucky enough to see your car last Sunday at the Black Swan - it looks fantastic.
It must be a bit "exciting" after a 2 litre - enjoy!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Spaniarduk
Same with mine. It was already doing ever since i got it with 24k miles. Very common. I always press the clutch just before stopping the engine to prevent my mechanical OCD-ness from wanting to spend a fortune on fixing nothing wrong.MichaelPorter80 wrote: ↑Fri Jun 14, 2019 9:24 am
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
