Oil change
Oil change
Managed to get a deal on 8ltrs of Castrol 10/60 so I can do an interim oil change. Is there anything different when doing an oil change on the S54 as opposed to a standard car?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Oil change
Did mine a few days ago there is a copper washer under the head of the drain plug you could get a new one or as I did reuse it if in good condition I also used a small amount of loctite sealant but only on the two threads at the head end of the bolt and on the copper washer.
Oil change
Thanks pal - is it 7ltrs?PDJ wrote: ↑Wed May 29, 2019 9:41 am Did mine a few days ago there is a copper washer under the head of the drain plug you could get a new one or as I did reuse it if in good condition I also used a small amount of loctite sealant but only on the two threads at the head end of the bolt and on the copper washer.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- R60BBA
Oil change
5.5 litres of 10w60Simon 3.2M wrote: ↑Wed May 29, 2019 9:49 amThanks pal - is it 7ltrs?PDJ wrote: ↑Wed May 29, 2019 9:41 am Did mine a few days ago there is a copper washer under the head of the drain plug you could get a new one or as I did reuse it if in good condition I also used a small amount of loctite sealant but only on the two threads at the head end of the bolt and on the copper washer.
Obviously don’t forget to change the filter too.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
Oil change
New oil filters come with a replacement copper crush washer, so reusing the washer, even with the Loctite involved, isn't great.PDJ wrote: ↑Wed May 29, 2019 9:41 am Did mine a few days ago there is a copper washer under the head of the drain plug you could get a new one or as I did reuse it if in good condition I also used a small amount of loctite sealant but only on the two threads at the head end of the bolt and on the copper washer.
If you are stuck and have to reuse a copper crush washer annealing it with a torch flame will return it to it's soft, "unused" state.
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
