Standard Z4MC Discs & Shockers
Very impressed with the service from Harry Fairbairn in Kirkcaldy - the full set of discs and pads arrived this morning via DPD
- A63B4E00-2E87-4466-9403-BD4EBC84717F.jpeg (307.29 KiB) Viewed 1312 times
Sapphire Black 23i
Previously 7xZ3's, 5xE85's, 2xE86's & 3xE89's
- abar121
Yup exactly. The monotube dampers that Bilstein usually use are much higher spec than most OEM shocks, certainly far superior to the stock Monroes. Whether you like the individual fitment is another issue.
'07 Z4M Interlagos Blue. All options except extended leather.
- R60BBA
OEM shocks are Sachs...
Shame the Bilsteins are not inox like KW though.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
This doesn’t really concern the Bilstein B6 as it’s simply a yellow painted non adjustable damper.R60BBA wrote: ↑Tue Mar 26, 2019 9:27 pmOEM shocks are Sachs...
Also, having had experience of Bilstein, KW, Ohlins and Nitron adjustable suspension, with regards to corrosion in daily use etc. I’d say the Nitrons were the best and all of them still require a level of user upkeep to maintain correct functionality.
- R60BBA
Mike. wrote: ↑Tue Mar 26, 2019 9:56 pmThis doesn’t really concern the Bilstein B6 as it’s simply a yellow painted non adjustable damper.
- A8019CE1-30C1-4D43-AF95-84BF574D2C1D.jpeg (370.1 KiB) Viewed 1244 times
- abar121
A friend who worked as a senior chassis consultant for BMW (and Lotus, Ford amongst others) and worked on the Z3M, E46 M3 and E39 M5 would beg to differ. Being able to work with such high quality suppliers such as Bilstein was a privilege according to him and very rare in the automotive field.
He was reluctant to work with BMW later on, as he was getting fed up of having to engineer in a 'sporty ride', for no dynamic benefit.
Anyway, it's all opinion, go with what you like.
- Attilio
deligthed to hear that: I am very impressed myself as they delivered to my local indy.
Best of luck!
A
Z4M Coupe, Interlagos blue, black leather, piano black, stubby, OEM CSLs, evolve intake, cup holders...pretty much stock
2019 Toyota Corolla hybrid 2.0L - new daily drive
Coilovers have arrived so now need to book it in for fitting along with the new discs
- 845517DC-AF8C-44C9-9390-AF67A03EC035.jpeg (383.52 KiB) Viewed 1148 times
- F807E95D-92FD-41A5-888C-628D4FF8DC0D.jpeg (358.37 KiB) Viewed 1148 times
Sapphire Black 23i
Are there any drawings of where all the bushes are located? Or are there kits available? I'm thinking of treating my '06 roadster.
I used them for my discs - you should be amazed by the improvement when fitted. The smoothness has returned to my car now that the balance has been returned. The discs are big lumps of metal and mine hadn't worn evenly.
I spoke to Powerflex and used the diagram in the following link https://www.powerflex.co.uk/products/Z4 ... 169/1.htmlMonster666 wrote: ↑Tue Apr 09, 2019 11:08 am Are there any drawings of where all the bushes are located? Or are there kits available? I'm thinking of treating my '06 roadster.
Sapphire Black 23i
So ahead of booking the car in for the discs and pads fitting and the suspension replacing I have been advised to replace the following:
Front wishbone bushes - £125 set
Front anti-rollbar bushes - £37 set
Engine mounts - £272 both
Advice was from manufacturer so really just looking to qualify before purchase - thanks in advance
Sapphire Black 23i
ThanksGwest44 wrote: ↑Thu Apr 11, 2019 11:30 amI spoke to Powerflex and used the diagram in the following link https://www.powerflex.co.uk/products/Z4 ... 169/1.htmlMonster666 wrote: ↑Tue Apr 09, 2019 11:08 am Are there any drawings of where all the bushes are located? Or are there kits available? I'm thinking of treating my '06 roadster.
Sapphire Black 23i
Sapphire Black 23i
