Abs sensor
"M" Specific discussion
mad4slalom
Abs sensor
Post by mad4slalom » Thu Feb 28, 2019 10:41 am
Hi again, anyone fitted abs sensors themselves. .? Any way of determining which one at fault without diagnostics?
Also any suggestions as to make, ecp are 57 quid, dont know how much oe ones are yet , some cheapies on ebay but unbranded so probably leave them alone. Also are all four the same or different front to rear or even sided as well. Any thoughts ,? Thanks in advance :thumbsup:
ph001
Abs sensor
Post by ph001 » Thu Feb 28, 2019 12:57 pm
Here you go... https://www.pelicanparts.com/techarticl ... cement.htm
If it's not visually wrecked from your garage burn out :driving: :evil: , the only easy way is to put a code reader on it. I'd defo take each one out and clean them up as a starter though. They got allsorts of crap and rust stuck to them.
mad4slalom
Abs sensor
Post by mad4slalom » Thu Feb 28, 2019 8:55 pm
ph001 wrote: Thu Feb 28, 2019 12:57 pm Here you go... https://www.pelicanparts.com/techarticl ... cement.htm
Brilliant, thanks ph, I will pull them and do as you say., daughters B/F is / was. Bmw stealer tech for last 6 years so borrowing reader from work. Will look at pelicanparts , many thanks. :thumbsup:
mad4slalom
Abs sensor
Post by mad4slalom » Thu Mar 07, 2019 10:30 am
mad4slalom wrote: Thu Feb 28, 2019 8:55 pm
hi PH, got m on the diagnostics and was fns abs sensor. All changed and lights all back to normal and hill start assist working again. Thanks for your advice 👍
ph001
Abs sensor
Post by ph001 » Thu Mar 07, 2019 10:33 am
:thumbsup:
