Engine oil choice
- Spaniarduk
Engine oil choice
In the past for previous cars i've had before my Z4MR I wouldn't have been too concerned about Engine oil brands. 'For a given spec all brands are the same', I used to say. But not for my Zeddie - oh no! Well..... may be... 'perhaps'.
I am looking at Mobil Engine Oil (10W-60 - 5ltr) and the usual Castrol Oil (10W-60 - 4ltr). Virtually the same price at Eurocarparts after the customary discount code. We all know 4L won't stretch, so i will need to buy an additional 1L.
What is everyone's experience with the Mobil Engine Oil 10W-60 over the Castrol equivalent? Will the engine use ( burn ) more of the Mobil? Will both oil brands perform the same?
Thank you kindly for your advice.
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Onlinemr wilks
Engine oil choice
4 + 1 won't do the job , you need 6 litres.
As for brand ? We all have out favourites & has to be the Millers CFS 10w60 for me
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Spaniarduk
Engine oil choice
mr wilks, do you use an oil pump to the dipstick or do you get umder the car? I use the former and normally get exactly 5L out, no more...
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Engine oil choice
Hi Andy
What oil would you recommend for my 35is. Ready to bring it out of hibernation now the weather has taken a turn for the better. Not meaning to hijack the thread.
Onlinemr wilks
Engine oil choice
Indy does it but always given 6litres or 2x5 litre then taken the surplus home . Always assumed it was a 6litre changeSpaniarduk wrote: βFri Feb 22, 2019 2:59 pm mr wilks, do you use an oil pump to the dipstick or do you get umder the car? I use the former and normally get exactly 5L out, no more...
- Screenshot_20190222-152450-01.jpeg (85.71 KiB) Viewed 1146 times
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Onlinemr wilks
Engine oil choice
I had two oil changes on my 35i, both times it was Millers 5w30 Trident ( fully synth not semi)
Just Β£26.50 on ebay at moment for 6litres delivered to your door
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Engine oil choice
I use Fuchs Titan race pro s, as I think Ester based oils are better. But any oil from the likes of shell, Mobil 1, Castrol etc will be fine. Check opie oils out for more info
Also you will need 6 litres for a full change not pumping via dipstick.
2nd gear sideways
- Spaniarduk
Engine oil choice
Thanks Matt.13
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- Spaniarduk
Engine oil choice
mr wilks, unfortunately the S54 engine requires 10w60, which is considerably more expensive
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Onlinemr wilks
Engine oil choice
Worth it though :winkSpaniarduk wrote: βFri Feb 22, 2019 6:07 pm mr wilks, unfortunately the S54 engine requires 10w60, which is considerably more expensive
Β£100 for the engine, diff & gearbox oil delivered from Opie or Β£65/Β£70 engine oil alone on ebay.
- DSC_3263-01.jpeg (145.34 KiB) Viewed 1101 times
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Engine oil choice
If that's the case I wouldn't be using that method. I use the traditional sump drain technique (under the car as you say) and I get closer to 5.5L.Spaniarduk wrote: βFri Feb 22, 2019 2:59 pm mr wilks, do you use an oil pump to the dipstick or do you get umder the car? I use the former and normally get exactly 5L out, no more...
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- road warrior
Engine oil choice
10-60 ???
Where did that come from, I thought cars used 5-30 these days?
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- -Tom-
Engine oil choice
This is for the s54 lumproad warrior wrote: βSat Feb 23, 2019 10:08 am 10-60 ???
-Z4 M Coupe, Silver Grey, Imola Red Nappa, carbon leather, CSLs, SuperSprint Race, Track Mode Enabled
-Tesla M3 LR
Previous - 3.0 si sport roadster, Silver Grey with Oregon Pearl Grey leather, Piano black, EIbach Pro, Stubby
-Tesla M3 LR
- Spaniarduk
Engine oil choice
Mangozac, do you use a lift or any other method to lift the car horizontally? otherwise I risk not being able 2 get all the oil out
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- road warrior
Engine oil choice
patience is the clue, go for a short run and warm up the engine, put the car on axle stands, open the drain plug and let it drain for an hour,Spaniarduk wrote: βSat Feb 23, 2019 11:41 am Mangozac, do you use a lift or any other method to lift the car horizontally? otherwise I risk not being able 2 get all the oil out
and be careful removing the plug cus it well now be hot of course. if it proves too hot let it fall into the drain tray and retrieve it later.
