I know most people like the MOS2 additive - but if you look at my report posted above, MOS2 additive didn't do anything for me. However, Liqui Moly's Ceratec did dramatically lowered my lead level and it appeared from my experiment that it's the only additive that's worthwhile to try, at least on my car. I don't like using oil additives in general. But after seeing some positive results from my own experiments, I will probably use a treatment of Ceratec every 30k miles or so in the future.
S54 oil analysis
- XMetal
S54 oil analysis
- R60BBA
S54 oil analysis
Regardless of your oil report, as the car has done 100,000 miles I would book it in for a rod bearing service.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- philipw
S54 oil analysis
So the shells are now replaced, bill came in at just over £2000, £1414 including inspection 2 and the rest on replacing other parts that showed wear. Vanos and differential were fine so that was a bonus. Pictures of the shells below, wear was mainly contained to the top shell with cylinders 4 and 6 being the worst.
Happy to have had this done as now I can chill and enjoy the car:)
- 20190216_121745.jpg (150.17 KiB) Viewed 1258 times
- 20190216_121739.jpg (145.75 KiB) Viewed 1258 times
08 Carbon Black M Coupe
- XMetal
S54 oil analysis
Good grief - those bearings looked horrible! I'm still stumped as why copper are not showing on these reports as expected.
Glad to see you had it done (just in time too) so you can really go enjoy it without worrying about bearings now
S54 oil analysis
What’s the going rate for rod shell replacement??philipw wrote: ↑Sat Feb 16, 2019 1:24 pm So the shells are now replaced, bill came in at just over £2000, £1414 including inspection 2 and the rest on replacing other parts that showed wear. Vanos and differential were fine so that was a bonus. Pictures of the shells below, wear was mainly contained to the top shell with cylinders 4 and 6 being the worst.
Z4MC
S54 oil analysis
What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
- philipw
S54 oil analysis
Thanks for linking to your thread, good source of information. Have to agree, shells 4/6 have wore well into the copper and way worse than yours. Hard to know how long they could have lasted before causing damage however I imagine a trackway would have shortened their life massively. This car has done 50K miles in the past 2.5 years so clearly low stress motorway mileage doesn't prevent shell wear, I imagine its all down to the way its driven until oil temp reaches 80 degrees and the fact that the conrod shells are a consumable item.
I too am confused why copper wasn't observed. I enquired with the lab and they stated that the method they used (inductive coupled plasma atomic emission spectroscopy) is accurate for quantitative analysis on a particulate scale but not for particles. If you look at shells 4/6, you will see pitting evident in the copper surface where tiny chunks of copper have been removed. It will always be very difficult to pick up these up as there will be very few of them in the oil and they won't be spread uniformly. Fourier transform Infra-Red spectroscopy is more suited to the detection of larger particles but it is limited to qualitative not quantitative so no use here.
- philipw
S54 oil analysis
Truth wrote: ↑Sat Feb 16, 2019 6:31 pmWhat’s the going rate for rod shell replacement??philipw wrote: ↑Sat Feb 16, 2019 1:24 pm So the shells are now replaced, bill came in at just over £2000, £1414 including inspection 2 and the rest on replacing other parts that showed wear. Vanos and differential were fine so that was a bonus. Pictures of the shells below, wear was mainly contained to the top shell with cylinders 4 and 6 being the worst.
Shells inc bolts as a one-off is £1070 including an oil change which for the specialist I used was £134. Parts cost is £420 for OE shells/bolts and 6 hours labour makes up the rest.Angelus666 wrote: ↑Sat Feb 16, 2019 6:33 pm What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
S54 oil analysis
Where abouts did you have this done and would you recommend them?philipw wrote: ↑Sun Feb 17, 2019 7:21 amTruth wrote: ↑Sat Feb 16, 2019 6:31 pmWhat’s the going rate for rod shell replacement??philipw wrote: ↑Sat Feb 16, 2019 1:24 pm So the shells are now replaced, bill came in at just over £2000, £1414 including inspection 2 and the rest on replacing other parts that showed wear. Vanos and differential were fine so that was a bonus. Pictures of the shells below, wear was mainly contained to the top shell with cylinders 4 and 6 being the worst.
Happy to have had this done as now I can chill and enjoy the car:)Shells inc bolts as a one-off is £1070 including an oil change which for the specialist I used was £134. Parts cost is £420 for OE shells/bolts and 6 hours labour makes up the rest.Angelus666 wrote: ↑Sat Feb 16, 2019 6:33 pm What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
Z4MC
S54 oil analysis
Was the crankshaft measured for wear and ovality of bearing surface, whilst the shells where changed.
- R60BBA
S54 oil analysis
I’d say you just got there in time.philipw wrote: ↑Sat Feb 16, 2019 1:24 pm So the shells are now replaced, bill came in at just over £2000, £1414 including inspection 2 and the rest on replacing other parts that showed wear. Vanos and differential were fine so that was a bonus. Pictures of the shells below, wear was mainly contained to the top shell with cylinders 4 and 6 being the worst.
Another 3,000 miles of hard driving and shells 4 and 6 could have spun.
As proven you cannot take oil analysis reports as face value.
Happy you’ve got it done and can now enjoy the car for the course of your ownership.
£800 - £1200 depending on which shells and bolts you go for. The job is about 7 hours labour.Angelus666 wrote: ↑Sat Feb 16, 2019 6:33 pm What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
Most BMW specialists can do this job. As long as the bolts are torqued correctly there’s not much to fear.Truth wrote: ↑Sun Feb 17, 2019 11:16 amWhere abouts did you have this done and would you recommend them?philipw wrote: ↑Sun Feb 17, 2019 7:21 amShells inc bolts as a one-off is £1070 including an oil change which for the specialist I used was £134. Parts cost is £420 for OE shells/bolts and 6 hours labour makes up the rest.Angelus666 wrote: ↑Sat Feb 16, 2019 6:33 pm What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
Any of the following indies are fully competent in carrying out this job:
Munich Legends / Haywards Heath
BMS Surrey / Leatherhead
Evolve Automotive / Luton
Redish Motorsport / Bristol
ETA Motorsport / Sevenoaks, Brands Hatch
BMR Performance / Crawley
Deutsh Tech / Milton Keynes
Mr Vanos / Darlington
- BMWZ4MC
S54 oil analysis
Phil at CPC Performance Engineering in Amersham changed mine at 50k miles. The peace of mind was worth the small expense and I’ll change them again at 100k miles even though there was no visible wear at 50k.R60BBA wrote: ↑Sun Feb 17, 2019 1:24 pm
S2000 GT - gone
S54 oil analysis
Wonder if there is a potential group buy here with one of those specialists. There’s a lot of Ms up at 70k + miles and I’d imagine a few of us would be looking to get this done over the next year.
- philipw
S54 oil analysis
Forza GB carried out the work, I have used them in the past on previous Z4's and have always had a good experience.Truth wrote: ↑Sun Feb 17, 2019 11:16 amWhere abouts did you have this done and would you recommend them?philipw wrote: ↑Sun Feb 17, 2019 7:21 amShells inc bolts as a one-off is £1070 including an oil change which for the specialist I used was £134. Parts cost is £420 for OE shells/bolts and 6 hours labour makes up the rest.Angelus666 wrote: ↑Sat Feb 16, 2019 6:33 pm What's the typical cost at a good specialist of just getting these shells replaced as a one-off job?
I was going to use Mill Lane Automotive in Bristol but they were booked up for the next three weeks and currently had two E46 M3s in the shop with bottom end knock. I have also used Clayton Cars in Bristol on other BMW's and have found their service to be good. As previously mentioned Redish Motorsport is another good option but they are always booked up due to their reputation of specialising in motorsport applications.
Yes the crank was checked, it aligned to OE specs and did not show any wear.
