The engine doesn’t work so well at 10’C though, that’s why you need to let it warm up. The tolerance at cold is to compensate for the operating temperature.ph001 wrote: ↑Sat Dec 22, 2018 10:41 pm The point about temperature is a good one. You will find the just having the ambient go from 7’C to 20’C will put them out of spec (yes the tolerance really is that tight). The fact that the engine has to work just as well at 10’C as it does a 90’C does make a bit of a mockery out of it imho.
Valve clearance check and shim replacement. Input from the DIY-er
- srhutch
- Moderator
- Spaniarduk
Thanks ph001
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- Spaniarduk
srhutch, also a good point.
Overall it os clear that to be able to do a good job of the valve clearance check it is best for the engine to be at about 20C
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- BMWZ4MC
Having seen the instructions with the kit, I’m think I’ll adjust the valve clearances on mine next time. It removes the stress of trying to find a competent mechanic with experience of the S54 in Sydney too.
S2000 GT - gone
Hey Spaniard,Spaniarduk wrote: ↑Sat Dec 22, 2018 4:40 pm john-e89, thanks John. I'll be plucking up the necessary bravery between now and the spring lol.
To be fair in my job I do carry out repairs (I'm a Carl Zeiss Confocal Microscopy service engineer) where in essence the processes and method are not that dissimilar. All i need is a quiet corner, pen, paper and break up the task. The rest comes on its own after that.
john-e89, it sounds like youve done this before. Where do you source your shims? Did you buy a whole kit or just the required ones, once you measured?
I used individual shims once I’d measured as these cars are a toy so time wasn’t an issue which was the best approach for me as I could get the exact shims I wanted. I can’t comment on the shim kits I’m afraid as I’ve never used one. Best of luck, I’m sure you’ll be fine.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Spaniarduk
Thanks john-e89, just what i was thinking. My Z4MR is a fair weather toy, so no particular rush in getting it done. Only shame is that I'll have to wait for the warmer weather to do it.
The kit mentioned in one of the other posts seems amazing value, though!
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
It does certainly, however my slight ocd would leave a thought always wondering if the kit shims are as hard as OEM, buying genuine shims knocks that issue out. Maybe they’re all made by the same people I don’t know but....you get it. But maybe that’s just me being a bit OTT admittedly.Spaniarduk wrote: ↑Sun Dec 23, 2018 2:58 pm Thanks john-e89, just what i was thinking. My Z4MR is a fair weather toy, so no particular rush in getting it done. Only shame is that I'll have to wait for the warmer weather to do it.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Darren Slone
Richard I’m coming over in April with Swmbo, with a bit of luck you’ll get that drink I owe you we’re staying in North Curl Curl on the Northern Beaches sorry OP for the highjack
Current Porsche Cayman S 987.1
Now sold - Imola Z4MC
Now sold - Silver Grey Z4MC
OEM CSL’s, Supersprint, Gruppe M, Eibachs, Carbon Roof, carbon rear spoiler,,
Now sold - My other Z
‘71 Datsun 240Z imported from West Coast USA
John, I've seen on the E46 forums people have had the Wiseco shims tested and shown them to be identical to the OEM shims in regards to size, hardness, etc. It's good enough for my level of OCDjohn-e89 wrote: ↑Sun Dec 23, 2018 3:46 pm It does certainly, however my slight ocd would leave a thought always wondering if the kit shims are as hard as OEM, buying genuine shims knocks that issue out. Maybe they’re all made by the same people I don’t know but....you get it. But maybe that’s just me being a bit OTT admittedly.
Edit: I decided to be less lazy and actually look up the post. I think this is as good a recommendation as any: http://www.m3forum.net/m3forum/showthread.php?t=467647
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- Spaniarduk
Mangozac, interesting read now ill have a look to see of we can get those shim kits in the U.K.
Thanks again
Thanks again
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- BMWZ4MC
Excellent, I’ll PM my number to youDarren Slone wrote: ↑Sun Dec 23, 2018 4:10 pmRichard I’m coming over in April with Swmbo, with a bit of luck you’ll get that drink I owe you we’re staying in North Curl Curl on the Northern Beaches sorry OP for the highjack
S2000 GT - gone
Well there you go, just ask someone who knows...Mangozac wrote: ↑Sun Dec 23, 2018 9:25 pmJohn, I've seen on the E46 forums people have had the Wiseco shims tested and shown them to be identical to the OEM shims in regards to size, hardness, etc. It's good enough for my level of OCDjohn-e89 wrote: ↑Sun Dec 23, 2018 3:46 pm It does certainly, however my slight ocd would leave a thought always wondering if the kit shims are as hard as OEM, buying genuine shims knocks that issue out. Maybe they’re all made by the same people I don’t know but....you get it. But maybe that’s just me being a bit OTT admittedly.
Thanks very much for that Mangozac, very good info.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
I’ve been using the wiseco shims for years and so far (touch wood) nothing out of the ordinary has happened. They don’t appear to wear abnormally compared to the oem shims and are still in spec when used and checked with a micrometer.
Apart from the shim tool, you’ll need a big ol’ socket to turn the engine-I think it’s 32mm from memory, but check that on one of the guides online.
RUBYIMOLACARBON
- Spaniarduk
Thanks beanie.
Every how many miles do you check the valve clearance? Do you find you have to replace shims every time you check the valve clearance?
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
They’re meant to be checked every inspection so that’s a maximum of about 28k miles if you go by the service indicator.
I tend to do them once, sometimes twice a year and although some might find it excessive, I’ve generally found I’ll need to change a couple of shims.
No harm to be doing it yearly imo and tbh, if mine was a track car I’d do it more frequently.
RUBYIMOLACARBON
