Vanne's lightweight/ interior modification thread
- Vanne
Yup, i just hope that the pre-load and balance are correct. id hate to be oversteering like a mofo if that isnt correct. Had a long discussion about that too.
Powered by Severn Tuning
- Vanne
And then we started with the race dash...
Really happy with how that turned out. Just roughed it in at the moment, will need to sort out the gauges and panel fitment.
I have some ideas on that, but will need to be fleshed out some.
- Vanne
Racingdiffs race diff arrived..
Holy s**t, comes with brand new output shafts.. unexpected..
- MrPT
That is the most hipster packaging for car parts I have ever seen.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Vanne
- Liam22
Love that ARB! I've been rethinking my setup recently. Do you know if your supplier has hollow/adjustable bars for the OEM pickup points?
- Vanne
Pretty sure they do Liam, have a look at ground control arb's mate, this one is a custom race version, but they have many.
- RedUn
IMOLA Z4///MR
- Vanne
They are at the top, these are in inverted. Lol.. have to still see which way they will be installed once the wheel is on properly installed. (They are only loosely installed at this stage and only to stop the suspension arm from hanging) but to answer your question, helper springs can go either place. Top or bottom. And these shocks can also be installed either way, upside down or right way up, just depends on how you fit them and for what reason. These have provision for remote canisters, and as such would be upside down, but as I have no need for that, leaves me open to install which ever way I like. Which might even be this way as the main body will see less fod this way.
- Liam22
Slightly less unsprung mass when fitted inverted.
- RedUn
Interesting never seen suspension you can fit either way before! Certainly different that! I'd fit them the other way to protect the damper rod from picking up damage?Vanne wrote: ↑Tue Nov 10, 2020 10:36 pm They are at the top, these are in inverted. Lol.. have to still see which way they will be installed once the wheel is on properly installed. (They are only loosely installed at this stage and only to stop the suspension arm from hanging) but to answer your question, helper springs can go either place. Top or bottom. And these shocks can also be installed either way, upside down or right way up, just depends on how you fit them and for what reason. These have provision for remote canisters, and as such would be upside down, but as I have no need for that, leaves me open to install which ever way I like. Which might even be this way as the main body will see less fod this way.
Fod, are you in aero?
IMOLA Z4///MR
- Vanne
Yup, sadly as it's probably the worst sector to be in ever. All of mates have gotten fired over the last 8 months. I'll have a look see after my wheels are fitted, depending on clearance.
- RedUn
Thought so, same here, bad times, lots going over here too, it'll be back though!
IMOLA Z4///MR
- Vanne
I sincerely hope so mate, only surviving as i am on the 777 fleet, nothing to do with skill or otherwise, just luck of the fleet. not sure how were gonna go though the 380 is like the Titanic, and will most likely take all of us down with it as it sinks down into the depths of stupidity.
On the upside, my Injectors arrived today.. and my diff is ready to be picked up...
- Vanne
Meanwhile...
(Old diff case, but new everything inside)
Gear paint.
Looks pretty good
backlash set.
Really looking forwards to this hooking up.
Gear paint.
Looks pretty good
backlash set.
