Hi there,
Anyone suffered from a hot start issue? The only thing I can think of that I've done differently is fill up on V Power.
So its been fine since rebuild but yesterday after driving back, parking up at Marks (say a 5 minute stop) It just wouldn't "catch" left it 5 minutes and then it started.
Anyone had this experience? thought I'd ask before getting it booked in.
Cheers,
T1b
Hot start issue
- T1berious
Hot start issue
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
- BMWZ4MC
Hot start issue
Any warning lights or fault codes?
S2000 GT - gone
- Ewazix
Hot start issue
In the old days fuelling issues would have the obvious place to look with hot start problems and fuel pump is worth bearing in mind as well as silly things like malfunctioning fuel tank caps/returns (when it happens remove the cap and see if it releases a substantial vacuum or cure it?), or on these cars MAFF / intake leaks around the flexi hoses are worth a check as previous posts suggest they don't always throw fault codes.
There are lots of other possibles but most should throw a code.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- tonyz4c
Hot start issue
did you noticed a louder exhaust sound when you drive after that
or you stall easily on 1st gear, rev drops down easily ?
Z4MC Carbonschwarz - Caramel
Database of M /3SI http://perso.numericable.fr/tonyz4c
- Mr Tidy
Hot start issue
My 3.0Si used to suffer from that when I first got it (in May 2016).
Then it needed a new battery that December and it's been fine ever since!
It might be worth seeing how old the battery is - anyway good luck getting it sorted.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
OnlineNictrix
Hot start issue
Could this possibly be a valve clearance issue?
If the valve clearances are out of spec, as in too tight, when the engine is warm the valves could be held open slightly.
If this happens it can cause problems with warm starting as it can lower compression.
- Adam D
Hot start issue
I have found my car doesn’t fire up so easily on vpower, maybe needing another rotation of the engine to catch. No idea why
Silver Grey 2007 Z4MR which needs to be driven more
