Hi All
I have been prepping my car for hibernation. Last weekend i ACF50 the underneath and left it sitting until now
I have just started the car up so i could place it in its Carcoon for the winter
EML and a few other lights popped on. Minimal revs and a bit lumpy
Don't have a coder, wondering if the knowledge out there can help or tell me which coder i need
A couple of lights on dash
- ClubberL
Gone 2006 Bmw Z4MR
Gone Bmw Z4 E89 2012 3.0 Highline M Sport
Gone BMW Z4 2008 E85 2.0 M Sport
I (very bizarrely) had all three of these lights appear on mine once as well as the tyre pressure monitor light.
Took the car to the petrol station and checked the tyres, one was low, very low, although not visibly so. After pumping up and re-setting the TPM, all lights disappeared. Had the tyre looked at a day later and the valve was leaking.
Odd, but has never happened again.
- ClubberL
So ordered a code reader last night. Left car half on trickle charge over night. Left work at lunch, perks of being self employed.
Got home started the car expecting to be lumpy, only 2 thousand revs and purrs once again with just the engine symbol on the dash and full revs
Feeling better........but not relaxing!
Gone 2006 Bmw Z4MR
- ph001
EML light is usually an indication of emissions related problems. I wonder if the ACF50 somehow got into the lambda sensors and caused it to temporarily throw a wobbly? Shouldn't though - ACF50 is normally fine to spray on anything electrical.
- Gustavo7
Mine started having the symptoms you mention a couple of months ago. Check if the battery is getting charged by the alternator or if it's not getting spikes due to a bad alternator. Mine cooked two batteries before I realised the problem was the alternator. Has even battery acid boiling out though the battery vent!ClubberL wrote: ↑Wed Oct 10, 2018 2:30 pm So ordered a code reader last night. Left car half on trickle charge over night. Left work at lunch, perks of being self employed.
Very simple to replace the alternator, can be done in less than 30min.
Imola Red Z4MC
- ClubberL
Well managed to get the codes read once the rain had stopped
Car back to normal, and dash cleared
- 20181016_140227.jpg (214.93 KiB) Viewed 1655 times
Gone 2006 Bmw Z4MR
- ph001
Weird. Probably never happen again but you could calibrate your throttle very easily just to make sure:
1 Place key in ignition and turn ignition on and count for 10 seconds ( only position 2 do not start the engine. )
2.Turn key back to position 0 and count for another 10 seconds
3.Now turn the key all the way to detent 3 to start the engine.
- ClubberL
Gone 2006 Bmw Z4MR
That’s odd! I had this issue after trying to pair my phone with car! Maybe I inadvertently calibrated my throttle?
