Rear Damper Data Point
- wyshyvanuk
Just pulled one of the original rear dampers on my 2008 Z4M Roadster with 46K miles. Completely shot. It collapses with relative ease, and, once collapsed, stays there without a hint of any effort to expand again.
Online
Data point 2:
Mine was on the originals all the way to about 120,000 miles (obviously past their best, but not 'broken' per se). Then I replaced the lot with Bilstein PSS10.
- MrPT
Thanks for posting this, but what do you mean “expand again”? It’s a damper so should resist force in both directions when unsprung.wyshyvanuk wrote: ↑Sun Sep 23, 2018 12:49 am Just pulled one of the original rear dampers on my 2008 Z4M Roadster with 46K miles. Completely shot. It collapses with relative ease, and, once collapsed, stays there without a hint of any effort to expand again.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- wyshyvanuk
Quite true, but they are also gas pressurized. When mounted, the barrel spring supporting the weight of the car will partially collapse the damper against that gas pressure. When a dip or pothole is encountered, that gas pressure will assist the spring in pushing the wheel down to maintain contact with the road surface.
- wyshyvanuk
mmm-5, I now have a serious case of suspension envy.
