As winter looms cTek...
"M" Specific discussion
mark seeker
Post by mark seeker » Wed Aug 29, 2018 11:51 am
Hi
As winter approaches I will definitely be using the Zed less, does anyone have a link to the easiest way to connect a battery conditioner at all? I've read it can be connected via the bonnet or boot? I couldn't find anywhere inside the bonnet then struggled to remove the top of the battery case in the boot (I blame the fact it is tight and dark in the garage). :roll:
Any help would be much appreciated
Online
mr wilks
Post by mr wilks » Wed Aug 29, 2018 11:58 am
The live connection is on bulkhead slightly to right of centre behind a small plastic flap , the negative is on passenger strut tower top ( its a hex bolt head )
E86
E85
Grey///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
Imola///MR
35i Msport 6spd
E86
Ti ///MR
E86
35is :driving:
https://www.instagram.com/andybmwheels/
nickw6666
Post by nickw6666 » Wed Aug 29, 2018 12:40 pm
I use the CTEK 12v outlet cable extension lead and charge the car through the cigarette lighter socket which works brilliantly on my Coupe. I route the cable through the boot and simply leave the boot hatch resting nearly closed.
I've charged this way for years and am still on my original battery with the car..
2007 Imola Red Z4M coupe. Owned for 11 years.
2015 F82 M4 coupe - Mineral White, M DCT
2006 BMW 335i SE Coupe - daily driver
Previous: 2007 Porsche 911 Carrera S
Online
Zoomer
Post by Zoomer » Wed Aug 29, 2018 1:36 pm
I a lead permanently connect to the battery terminals in the boot. Just disconnect boot light
Silver 3.0i Z4 now gone
Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Intravee ,Cruise and a nice warm garage.
srhutch
Moderator
Moderator
Post by srhutch » Wed Aug 29, 2018 1:38 pm
MY CTEK is connected using the patch cable directly to the battery. You can also close the boot fully and lock the car.
The cable is fine as there is plenty of give in the seal.
tadekk
Post by tadekk » Wed Aug 29, 2018 1:46 pm
I don't think you need to do that - the boot light seems to go off after few minutes automatically even with the boot lid open.
Online
Jembo
Post by Jembo » Wed Aug 29, 2018 4:18 pm
I’ll let you know how my Solar charger looks after my //M during the winter months... next year
Its just had a 6 week test & span up strongly... fingers x the trickle over shorter days connected through dedicated battery leads will keep it healthy, with a couple of warm ups during the winter months.
Went for solar (a) because no garage power (b) didn’t think a perm charge was as good as an intermittent charge
The dark side with a ///M Hell Bronze Sepang Coupe :happyclap:
Lifer 54
Online
2dogs
Post by 2dogs » Wed Aug 29, 2018 4:48 pm
+1 :thumbsup:
Blue Z4MC
mark seeker
Post by mark seeker » Fri Aug 31, 2018 8:51 am
Many thanks for this - much appreciated.
Bigpow
Post by Bigpow » Wed Oct 24, 2018 2:35 pm
I run the cable under the bonnet with no problems. Ctek used as well 👍🏻
Z4MR - Sapphire black.imola.carbon.19" csl's.
PerryGunn
Post by PerryGunn » Wed Oct 24, 2018 3:50 pm
... didn’t think a perm charge was as good as an intermittent charge
The CTEKs are intelligent chargers (as are a number of others) - they don't keep charging the battery all the time but monitor battery voltage and only start to recharge it once it drops below a certain value
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
RedUn
Post by RedUn » Wed Oct 24, 2018 8:13 pm
What he said :thumbsup:
IMOLA Z4///MR
