What did you think? I never had the stock suspension on mine so only have the non-M to compare to. They are in a different league, damping-wise, but I still wish I had a bit more rear travel.Bodyboarder wrote: ↑Sat Sep 01, 2018 7:33 pm Thanks Rob ( rally) for the very kind passenger ride in your lovely MR running the kw’s ..... now comes the hard part , justifying it in my mind that they are worth it for my needs
Suspension upgrade
- MrPT
Suspension upgrade
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Argenta
Suspension upgrade
I’m also a very happy owner of Eibach Pro springs/oem shocks. In my view how the Z4M should have left the factory.
Will however put on the KW V3 kit in a few weeks, as I already have it. Will get back with my 5cents.
Suspension upgrade
Yes I really liked them ..... but I’m struggling to justify the cost /hassle ! If I need to run 10mm spacers , that means running a slightly stretched tyre , so new Tyres , fitting , setting up properly... and so and so on !MrPT wrote: ↑Mon Sep 03, 2018 8:48 pmWhat did you think? I never had the stock suspension on mine so only have the non-M to compare to. They are in a different league, damping-wise, but I still wish I had a bit more rear travel.Bodyboarder wrote: ↑Sat Sep 01, 2018 7:33 pm Thanks Rob ( rally) for the very kind passenger ride in your lovely MR running the kw’s ..... now comes the hard part , justifying it in my mind that they are worth it for my needs
Gets the flame suit ready ..... although I did think they are were very good , the eibach springs for the money are also very good indeed in my opinion, coupled with the new rear bush’s and limiter kit , I think I’ll be happy enough ..... I have ohlins on my s2k and again in my opinion are a step above the kw’s , so comparing the kw to ohlins I’m not sure I’d be happy .
I must be getting old as I’m starting to think more about these big purchases and if for my use they are worth it .
