Differential Upgrades
Thanks for the advice!
But darn it, I wish I'd not seen the vids of the cars running 3.91 diffs - looks like a super upgrade......!
More thinking / saving to do...!
Who would you use to rebuild it / replace the seals?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- BMWZ4MC
As testimony to the durability of the standard differential, I have used my ///M as a track car for nine years covering thousands of miles without any problems.
S2000 GT - gone
http://www.jcracing.info/
In Thirsk
Speak to theses chaps as build loads of diffs for M3’s running in most race series throughout the U.K.
In Thirsk
Thanks All!
Looks like I'll be going for rebuilding the standard diff with a 3.91 ratio - watch this space...
- Vanne
Interesting..
Powered by Severn Tuning
- exdos
I did a diff ratio swap on my Z3MC in 2010 from OEM 3.15 to 3.46. When I did some datalogging from the ECU using various parameters, the swap didn't make any significant difference to on-road performance and just increased fuel consumption. For me, it was a waste of time/money and I went back to the OEM ratio.
Good to know Exdos - I'm still pondering this one...
- bradz
I have just taken the plunge and purchased a Gripper 12 Plate diff & BMW 4.10 final ratio.
This is for my e46 M3 though (Track car)
After doing a bit of research is seams the 4.10 is the one to go for, Takes the top speed down to about 170 but it will get there pretty quickly! apparently its the equivalent of 40bhp
https://www.automac.co.uk are building mine.
Adam
Adam
Z4M Coupe, E92 M3, E46 M3 Track car
- TomK
Cool let us know how you get on with it! I've heard really good things about the gripper and been looking at the same solution, it makes a lot of sense in terms of performance and economics.bradz wrote: ↑Thu Dec 13, 2018 10:35 pm I have just taken the plunge and purchased a Gripper 12 Plate diff & BMW 4.10 final ratio.
Adam
For me it'll be an 8 plate and the 3.91 cwp as my car is still supposed to be not too unpleasant on the road (think the 12 plate is a bit on the noisy side?).
- bradz
Cheers I will do.
Automac who are building it said the 12 plate will be noisy at low speed on the road and will push the front at very low speed. (This was a concern of mine as I still drive to tracks & the ring) They said its not horrific and the way it hooks up on track will make it worth it, They also said when it goes in for its 12 month checkup if I wanted they could change it back to a 8 plate for no extra cost.
That was enough to persuade me to go all out!
- TomK
Can't argue with that! Keep us postedbradz wrote: ↑Thu Dec 13, 2018 11:44 pm Cheers I will do.
- GuidoK
Thats the result of a very blunt calculation.
Its the equivalent of 44bhp for 77% of the time and a loss of ~82bhp for 33% of the time.
Only when you're in the same gear you have the 44bhp advantage, but with the shorter gears you have to shift up earlier, resulting in much much less wheel torque (and equivalent power).
Its a difficult exact calculation to make. The powerpart when you're in the same gear its easy, but the percentage of time and drop in power when going in different gears is difficult because not every gear is equally spaced. For the percentage I took gear 1-3 (so thats accelerating up to 100mph on the standard final drive), and the loss in power when riding in a higher gear I took the difference between 2nd and 3rd gear (the loss in power between 1st and 2nd is bigger as the corresponding difference in gearing is bigger).
0-60 will be faster with the short ratio but 0-105 will be slower (and 0-90 will be quicker).
So it really depends on what exact speeds you try to reach.
But the +40hp gain is not true (well, its true for 77% just as the loss of ~82hp is true for 33%).
In the end the gain is 0%. The ratio that maximizes the end speed reached wins.
Happy New Year everyone! I've just spoken with my local Indy and they are suggesting getting a standard diff rebuilt to standard spec is going to be tricky due to lack of parts availability. Not sure how true that is so any advice on that is much appreciated!
Just looking at the above, the gripper diffs are also a tempting option - is there a ballpark price for the build?? I'd probably keep the 3.64 ratio and something not too aggressive as the car is mainly used on the road.
It seems to me to be much easier to just swap the whole unit than have to go through the pain of taking the diff out and then have the car hanging about for weeks whilst the diff is sorted...
As ever, any advice is much appreciated!
OnlineR60BBA
Standard diff is good enough for road use.
If you want a track focused car then I recommend the BMW Motorsport 4:10 diff.
Darragh Doyle (ex F1 tech) @ Everything M3’s can rebuild a diff to your specification at a reasonable price.
Skip to 12 mins 40 sec:
Website: https://m.facebook.com/pages/category/C ... 713409262/
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
