BMW flash
"M" Specific discussion
Rally
BMW flash
Post by Rally » Sat Aug 04, 2018 1:54 pm
Had anyone had issues with bmw flash accessing the ecu?
Imola z4mr, carbon graphite ispiri FFR-6, mpss, gruppem, kw v3, oe strutbrace, aero skirts, schmiedmann carbon splitter, bcs exhaust, dice media, gaptech, F10 zhp & smiles every journey.
TomK
BMW flash
Post by TomK » Sat Aug 04, 2018 1:59 pm
Rally wrote: Sat Aug 04, 2018 1:54 pm Had anyone had issues with bmw flash accessing the ecu?
Given it's for the mss54 series I suspect you will have issues, the ecu in these cars is mss70.
TomK
BMW flash
Post by TomK » Sat Aug 04, 2018 2:04 pm
If of interest I am working with Martin of ecuworx to develop his fantastic binary mod tool for our ecu.
Let me know what you want to do with it and I'll try get it added to the feature list.
https://www.ecuworx.co.uk
Presently of interest is
- Adjust throttle map curve
- Disable secondary air pump
- Disable fault code / check engine light for physical removal of the secondary air pump
- Disable fault codes / check engine light for cat deletes
- Disable CAT Protection (Disables Enrichment)
- Shift Lights
- Final Drive ratio adjustments (for those who change diff ratios )
RedUn
BMW flash
Post by RedUn » Sat Aug 04, 2018 2:38 pm
Does the cat one also get rid of the light with decats?
IMOLA Z4///MR
beanie
BMW flash
Post by beanie » Sat Aug 04, 2018 2:48 pm
TomK wrote: Sat Aug 04, 2018 2:04 pm If of interest I am working with Martin of ecuworx to develop his fantastic binary mod tool for our ecu.
If possible then perhaps these can be integrated. I imagine some of these are probably covered by other software but it would be nice to have it all in one simple to use package.
-Turn off Airbag warning lights
-Reset/adjust Service schedule indicator
-Reset adaptations
-M-track (or whatever the intermediate DTC setting is called)
RUBYIMOLACARBON
