Huh?
Z4m in for Inspection II (Ongoing issues)
- R60BBA
Z4m in for Inspection II (Done, Costs shown)
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- Popey
Just got the car back and all my on going issues seem to of been solved. No more dropping revs and been lumpy when cold.
Fingers crossed
Fingers crossed
- Popey
Back tomorrow for a new battery
- Darren Slone
Got mine back today Gary and none of mine needed shimming either, all in spec, got my valve report, it’s my friends garage so I know they’ve been checked, bit like taking it to you really, he provided the Engine oil, filter and G/B oil, I provided the valve gasket and diff oil, the air filter and plugs didn’t need changing, I changed those less than 4K miles ago, a couple of ancillary belts, B/F and MOT too for under £500
Current Porsche Cayman S 987.1
Now sold - Imola Z4MC
Now sold - Silver Grey Z4MC
OEM CSL’s, Supersprint, Gruppe M, Eibachs, Carbon Roof, carbon rear spoiler,,
Now sold - My other Z
‘71 Datsun 240Z imported from West Coast USA
- Popey
So Darren Wood are now saying my new alternator is faulty. Not sure what the odds are but I’m pissed off it wasn’t checked before handing it back.
It’s going to BMW under parts warranty to be replaced if it is faulty that is.
To make things worst it’s still randomly cutting out and revs drop low too. I guess this could still be the faulty alternator.
I think I’ll get the alternator checked / replaced under warranty and then head to zed shed for a second opinion.
- R60BBA
Exactly, a good engine shouldn’t actually need the valves shimming. But in order to know this the valves have to be checked in the first place.Darren Slone wrote: ↑Fri Aug 17, 2018 6:33 pmGot mine back today Gary and none of mine needed shimming either, all in spec, got my valve report, it’s my friends garage so I know they’ve been checked, bit like taking it to you really, he provided the Engine oil, filter and G/B oil, I provided the valve gasket and diff oil, the air filter and plugs didn’t need changing, I changed those less than 4K miles ago, a couple of ancillary belts, B/F and MOT too for under £500
Dunno about Z4M-2006 interpretation ‘skills’.
- AndyBeech
What’s a ‘good’ engine got to do with it? Shims wear with use?R60BBA wrote: ↑Sat Aug 18, 2018 9:54 amExactly, a good engine shouldn’t actually need the valves shimming. But in order to know this the valves have to be checked in the first place..Darren Slone wrote: ↑Fri Aug 17, 2018 6:33 pmGot mine back today Gary and none of mine needed shimming either, all in spec, got my valve report, it’s my friends garage so I know they’ve been checked, bit like taking it to you really, he provided the Engine oil, filter and G/B oil, I provided the valve gasket and diff oil, the air filter and plugs didn’t need changing, I changed those less than 4K miles ago, a couple of ancillary belts, B/F and MOT too for under £500
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
- Nictrix
Not only that but the head can wear also.AndyBeech wrote: ↑Sat Aug 18, 2018 10:34 amWhat’s a ‘good’ engine got to do with it? Shims wear with use?R60BBA wrote: ↑Sat Aug 18, 2018 9:54 amExactly, a good engine shouldn’t actually need the valves shimming. But in order to know this the valves have to be checked in the first place..Darren Slone wrote: ↑Fri Aug 17, 2018 6:33 pm Got mine back today Gary and none of mine needed shimming either, all in spec, got my valve report, it’s my friends garage so I know they’ve been checked, bit like taking it to you really, he provided the Engine oil, filter and G/B oil, I provided the valve gasket and diff oil, the air filter and plugs didn’t need changing, I changed those less than 4K miles ago, a couple of ancillary belts, B/F and MOT too for under £500
Sometimes a quiet engine can mean shims need to be changed as the head can wear and close the valve clearance meaning sometimes there is either no clearance at all or the valve starts to be held open slightly.
It would be unusual but not impossible to not need any shims changed in an engine but if they have supplied proof via a sheet of paper showing what each valve clearance was it goes part way to showing they were checked. The only thing you wouldnt know would be if that info was for your car or not.
Its rare that the S54 doesnt need shimming.Although it does depend on what miles are being done inbetween services of course and overall mileage of engine and how its used.
As said,shims wear,cams wear and you can actually get a bit of valve seat regression,and the valve clearance ends up a little too tight.
I have probably done 20+ valve clearance checks on S54's and everyone i have ever done has needed shims,i think 3 was the least amount.
So my "interpretation" comes from experience,like Daz's though there is always exceptions to the rules.
- R60BBA
You didn’t service my car though did you?
Shame about that arrogance
No, your right..
I wouldnt service your car.
- R60BBA
No one asked you to.
I go to proper mechanics!
Keep with your garage ..Your obviously happy.
Ignorance is bliss.
How much did they charge you for the cam cover gasket,plug recess gaskets and bolt hole "O" rings ?
Ignorance is bliss.
- R60BBA
Call them and ask.
Good day!
Good day!
- 066D2FB4-B301-4367-B6B6-C216F7A9B489.png (155.18 KiB) Viewed 739 times
Prefer you to tell me off your receipt ?
