Engine mounts
Engine mounts
Whilst the subject of poly bushes for the lollipops is being discussed, what are people's thoughts on engine mounts - OEM or uprated?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Engine mounts
I'd check they actually need doing before committing, I had mine checked during Inspection 2 based on recommendation on this forum. I was also in an open wallet mentality towards the car during this and my independent knew this... great opportunity to say they need doing and charge me but they said they were fine, original, 2007 car with 55k miles.
- tomscott
Engine mounts
The vibratech mounts make the car feel more planted but I seem to remember members who have installed them have reported creaking. Beedub has them I think so worth asking him
On the case of doing them. These are IMO just as important if not more important than the bearings as these are age related items just as they are mileage. They are rubber and I think its the passenger side that is right next to the heat shield making that one perish faster, they compress and perish. In some cases they completely separate. At the age of these cars 10-12 years old I would say regardless of mileage they should be on the list.
There are signs. They can leak but there is a shield so unlikely you will see any fluid on the driveway. When the mounts have compressed there is more vibration from the engine and the engine itself can move more than it should under torque if the mounts have separated. This is why having the engine bolts changed is a good idea too as these were a fault anyway but they can get loose and under more strain can also snap. I think TomK had this issue the bolts had sheared completely.
At the end of the day they are hard to get to and you cant see them unless you remove the undertray, they could well be perished or separated but while the engine is off all weight is on them so you wouldn't know if they were separated. You would also only be able to compare when they come out.
Again if your having the bearings done it makes sense to have them do at the same time for piece of mind it shouldn't cost a lot. Engine movement can cause big bills as its connected to the trans etc and the vibration and torque movement will flow to everything connected.
Failure and separation
Compression
Complete failure
Compression
Complete failure
Engine mounts
I've had the bearings done Tom and the Indy said they were fine and didn't recommend uprated mounts. They don't look difficult to change - just remove the under tray and aluminium support and you can access the bolts through the wishbone.tomscott wrote: ↑Wed Aug 01, 2018 12:51 pm The vibratech mounts make the car feel more planted but I seem to remember members who have installed them have reported creaking. Beedub has them I think so worth asking him
Compression
Complete failure
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Engine mounts
I have the Vibratechnic road set on mine, and can’t say I’ve noticed any additional NVH over standard.
They look better than OE ones too...
- TomK
Engine mounts
Nope, not me.
I changed mine at about 60k for the vt road mounts. Original bolts hadn't backed out at all and the mounts themselves looked absolutely fine.
I can't say I noticed much difference really, although I would say the 2nd gear denial syndrome was definitely improved, so worth it for that alone imo, especially as it takes provably 10 mins to do on a lift.
Engine mounts
^^^ +1 for what TomK says above - I've got VT mounts on mine - no increase in NVH at all but definitely a tighter feel up front and a real improvement to 2nd gear denial...
Engine mounts
Another happy Vibratech user here, one of the most cost effective mods I've ever done on a car.
- tomscott
Engine mounts
Ah ok must be someone else!TomK wrote: ↑Wed Aug 01, 2018 1:55 pmNope, not me.
Anyway all knowledge is good knowledge.
Engine mounts
Correct
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- Jembo
Engine mounts
I have VT mounts, they’re well hidden once fitted though can’t comment on benefits as fitted by last owner along with the rear top mounts.
One of those small but cumulative mods that every day make our toys that bit better.
Lifer 54
Lifer 54
- MrPT
Engine mounts
And with no lift available? Could you safely put the car on axle stands and use a jack plus some kid of load spreader (aka a plank) to take the weight of the engine while you replace the mounts? Is there enough clearance to torque the bolts properly?TomK wrote: ↑Wed Aug 01, 2018 1:55 pmNope, not me.
Lots of questions, sorry. It’s just not something I’d considered I could do myself before.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Engine mounts
You could hire a ramp for an hour MrPT at one of those places with a few ramps for the public to use. Use a gearbox stand to take the engine once it’s in the air.MrPT wrote: ↑Wed Aug 01, 2018 10:13 pmAnd with no lift available? Could you safely put the car on axle stands and use a jack plus some kid of load spreader (aka a plank) to take the weight of the engine while you replace the mounts? Is there enough clearance to torque the bolts properly?TomK wrote: ↑Wed Aug 01, 2018 1:55 pmNope, not me.
Or hire an engine hoist on wheels and chain the engine that way. Planks sound a bit heath Robinson and would be in the way.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Engine mounts
I think you can put axle stands on the front, remove the aluminium under tray, undo the mount bolts , jack the engine (place wood in between) swap the mounts and reverse what you've just done. Not sure if I'm over simplifying the procedure but I'm sure others can comment. I'm not sure of torque figures though.MrPT wrote: ↑Wed Aug 01, 2018 10:13 pmAnd with no lift available? Could you safely put the car on axle stands and use a jack plus some kid of load spreader (aka a plank) to take the weight of the engine while you replace the mounts? Is there enough clearance to torque the bolts properly?TomK wrote: ↑Wed Aug 01, 2018 1:55 pmNope, not me.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
