Engine hesitation
"M" Specific discussion
Bodyboarder
Engine hesitation
Post by Bodyboarder » Thu Jul 19, 2018 6:14 pm
Hi all ..... sorry hitting this M specific section pretty hard at the moment!!
On medium to hard throttle at around 1500-3000 rpm I’m getting a hesitation/jerk like issue , feels like you’ve come on and off the throttle really quick . What’s people thought and anyone else had the same issue?
The car has a maf/brake booster valve issue and the booster valve has been ordered . Could this be related also ? If it’s throwing the maf readings out could this cause the hesitation at all?
Other thoughts are throttle position sensors ....
Bodyboarder
Engine hesitation
This is happening once warmed up for reference
Bodyboarder
Engine hesitation
Post by Bodyboarder » Thu Jul 19, 2018 6:48 pm
And also has a k&n drop in filter
Spaniarduk
Engine hesitation
Post by Spaniarduk » Thu Jul 19, 2018 8:34 pm
I once read in a BMW technical paper that in case of light opening throttle hesitation on of the things to look out was cold air intake and high flow air filters. Perhaps worth a try with an oem paper filter.
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo :)
Bodyboarder
Engine hesitation
Post by Bodyboarder » Thu Jul 19, 2018 8:45 pm
Worth a shot .... although I have just bought a gruppeM for it :lol:
For the sake of £10 I might just put a standard one in and see if it helps or not
Online
mmm-five
Engine hesitation
Post by mmm-five » Thu Jul 19, 2018 10:12 pm
Any leaks in the intake boot (between the airbox and plenum)?
I had that about 60,000 miles ago, but thought it was a MAF issue, and replaced that first :headbang:
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
Bodyboarder
Engine hesitation
Post by Bodyboarder » Fri Jul 20, 2018 8:09 am
You saying that makes me think it could also be related to my maf/brake booster fault code . The brake booster valve /solenoid goes from the inlet elbow and if thats faulty could be letting not enough/too much air through and causing the maf fault /hesitation that I’m getting .
dannytheduck1985
Engine hesitation
Post by dannytheduck1985 » Sat Jul 21, 2018 12:15 am
Get her scanned mate. Some issues don’t always throw up a dash warning light. Sounds like a miss fire to me.
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
Bodyboarder
Engine hesitation
Post by Bodyboarder » Sat Jul 21, 2018 8:49 am
seems to be happening when you’ve been out for a good blast and the engine is obviously running hotter than normal..... ?
Would a dodgy coilpack do this once it gets really hot?
620turbo
Engine hesitation
Post by 620turbo » Sat Aug 11, 2018 10:47 pm
Is it similar to this?
viewtopic.php?f=9&t=39891
tom21
Engine hesitation
Post by tom21 » Sat Aug 11, 2018 11:21 pm
I had a similar issue, fixed it by changing the Mass Airflow Sensor on the air intake. Are you able to scan the error codes?
Z4 MC Silver grey, Gruppe M, Supersprint manifolds back, schrick cams, strong strutbrace, lightened pulleys, UUC flywheel, short shift, paddle clutch, OEM CSLs, Ground control coilies, turner tie arms, bush limiters, Stoptech BBK. 370BHP
ph001
Engine hesitation
Post by ph001 » Sun Aug 12, 2018 8:08 am
Sounds electrical to me. Coil packs is where I would start.
2004 E46 M3 coupe manual.
Yeddheng
Engine hesitation
Post by Yeddheng » Mon Aug 13, 2018 12:32 pm
Does it feel like a vague bounce at a rate of 3-4 bounce per second?
Almost like this:
Z4 MC 07 / A08 Silver grey / Black w Carbon leather / VT+RE mounts / 10.9 / cdv- / RPi / Cup2 / Arc-8 / Lugs / Eibach drop / Custom alignment / Aux / Stubby / Mud flaps /
My Z4MC
crustyclown777
Engine hesitation
Post by crustyclown777 » Tue Aug 14, 2018 9:38 pm
Try removing the MAF and running the car to see if the issue is gone.
Z4MC Interlagos Blue
Instagram: z4mcuk
Bodyboarder
Engine hesitation
Post by Bodyboarder » Tue Aug 14, 2018 9:53 pm
Changed the maf for a new one , new air filter ( was a k&n ) seems to have done the trick :thumbsup:
Also bought a new throttle position sensor ... as I’m planning on removing the intake plenum, cleaning the icv and while it’s apart makes sense to change that to sensor underneath :thumbsup:
Also one coil pack is not a Bosch one , so bought a bosch one to replace it with ... makes my ocd happy :lol:
