Strut Bar and Tower bars
"M" Specific discussion
srhutch
Moderator
Moderator
Post by srhutch » Sat Jul 07, 2018 10:40 pm
TomK wrote: Fri Jul 06, 2018 10:36 pm
FD3S wrote: Fri Jul 06, 2018 9:22 pm
srhutch wrote: Sun Jul 01, 2018 9:59 pm Quick look at those and think they all use factory mounts so no good for you.
There is one, normally in White that would work though but no idea of quality
https://www.ebay.co.uk/itm/Ultra-Racing ... SwmrlU1OTa
Thanks srhutch looks solid and serves all the needs at once.
If you had a normal Z yes, but these won't fit the M, oil filler cap gets in the way iirc.
Think that’s the N52 that has that issue. Same with factory brace, which is fine on S54 but covers the oil cap on N52.
TomK
Post by TomK » Sun Jul 08, 2018 8:34 am
srhutch wrote: Sat Jul 07, 2018 10:40 pm
Not sure, I just know when I tried one on my car it didn't fit.
Note that brace is dead straight from tower to tower, whereas the factory one curves and thus avoids the oil filler cap on the S54.
wyshyvanuk
Post by wyshyvanuk » Mon Jul 09, 2018 2:22 am
Slightly off topic. Just reviewed my strut braces expecting to see two bolts attaching the braces to the strut tower. Car was manufactured in 10/2007, Z4M Roadster. Alas, passenger side has the bolt, but driver’s side has the nut. LHD configuration. No evidence of accident damage. Has anyone else been the victim of this dimorphic aberration?
Also, will attaching a brace across the strut towers act, among other things, to reduce the stress on the original strut tower to firewall braces? Thanks for any insight!,
FD3S
Post by FD3S » Wed Jul 11, 2018 10:04 pm
wyshyvanuk wrote: Mon Jul 09, 2018 2:22 am Slightly off topic. Just reviewed my strut braces expecting to see two bolts attaching the braces to the strut tower. Car was manufactured in 10/2007, Z4M Roadster. Alas, passenger side has the bolt, but driver’s side has the nut. LHD configuration. No evidence of accident damage. Has anyone else been the victim of this dimorphic aberration?
Some photos would help about it.
srhutch
Moderator
Moderator
Post by srhutch » Wed Jul 11, 2018 11:16 pm
This rings a bell. Somebody else reported similar from memory.
dannytheduck1985
Post by dannytheduck1985 » Thu Jul 12, 2018 9:45 pm
You been launching the car? Looks like a touch of the duck lead foot :D
Nah in all fairness the factory welds are complete s**t. Couple of tacks......... that will do. We slate BL for slap dash but they all at it.
You need a professsional fabricator mate. If your U.K. based I’m happy to point you in the right direction. First off get the idea the proper man for the job has to be within a certain radius out your head. Sending your pride and joy that little bit future could save you a complete nightmare in the future.
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
GuidoK
Post by GuidoK » Fri Jul 13, 2018 12:30 am
Its not touching the oil filler cap (I think the z4m oil filler cap is even placed more to the front than the m54 one).
It touches a hose from the icv system if I look correctly:
https://www.zpost.com/forums/showthread.php?t=949517
Might be do-able to fix that though.
TomK
Post by TomK » Fri Jul 13, 2018 8:03 pm
GuidoK wrote: Fri Jul 13, 2018 12:30 am
You're quite right, it was 4 years ago or so when I tried it, my memory fails me :D
