Strut Bar and Tower bars
"M" Specific discussion
FD3S
Post by FD3S » Sat Jun 30, 2018 9:08 pm
The last week a noise started braking my nerves while driving the car. The sound was metallic and today that I went to the mechanic, we discovered that I have a broken Tower brace. You can see attached the images.
Should I buy a new one or should I weld the old one? Is it something that will happen again?
Ducklakeview
Post by Ducklakeview » Sat Jun 30, 2018 9:27 pm
I've seen quite a few of these, I believe there was a recall or QA fix for sub standard welds..
Mike
Mangozac
Post by Mangozac » Sat Jun 30, 2018 10:33 pm
Either way there's a fair bit of metalwork and rewelding required :(
The part itself is surprisingly cheap though, so I'd just replace it:
http://www.realoem.com/bmw/enUS/part?id ... 1007193040
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Worcester_spoon
Post by Worcester_spoon » Sat Jun 30, 2018 11:32 pm
Looks like it’s the bracket that’s broken, not the bar, so looks like it’ll need welding whatever you do.p (*edit* which I’ve just realised is exactly what the other 2 answers say - note to self, read the whole thread first!)
03 Z4R 3.0i/Silver/stubby/Stormwerks knob/19" 313 reps/Parrot/gapTech/B12 kit/custom quad/CDV delete/ultimate racing strut/M3 ARB/turner RTAB limiters/ram scoop/330d brake upgrade/a giant smile on my face
Vanne
Post by Vanne » Sun Jul 01, 2018 11:29 am
Just weld up the bracket, no worries :thumbsup:
2007 EuroSpec Z4///MC Carma FF. DMK USSk. CDV X. RPi. CSL 19". Apex. APR Aero. CSL intake. Epic Alpha-N. KW Cs. 288/280. SS S1.Varis. Me STB. Brembo GT. Tillett. RE Xpipe. JB.
FD3S
Post by FD3S » Sun Jul 01, 2018 8:26 pm
Mike
Duck thanks for the answer. I googled yesterday for any recalls for the Z4M but couldn't find anything related. Let me know if you have something in mind.
srhutch
Moderator
Moderator
Post by srhutch » Sun Jul 01, 2018 8:41 pm
I don’t believe there has been a recall for this issue.
FD3S
Post by FD3S » Sun Jul 01, 2018 9:03 pm
Xaxa indeed it must be the cheeper thing about our cars. :)
Guys would you think the replacement with a full kit of tower and strut bars? I found the following available options for our cars.
The OEM solution is not valid since it is sold out.
Strong Struts
http://www.strong-strut.com/Z4/front_%2 ... rut/Z4.htm
Turner Motorsorts
https://www.turnermotorsport.com/p-1225 ... r-m-coupe/
Cosmo Racing
https://www.cosmoracing.com/E85-E86-MRO ... 54-MZ4-Z4M
Racing Dynamics
https://www.racdyn-usa.com/PROD/196+99+85+011.html
Mechunic
https://bimmian.com/Accessories-for-BMW ... rs/?veh=Z4
Mason Engineering
http://www.masonengineering.net/Subpages/Z4.htm
srhutch
Moderator
Moderator
Post by srhutch » Sun Jul 01, 2018 9:59 pm
Quick look at those and think they all use factory mounts so no good for you.
There is one, normally in White that would work though but no idea of quality
https://www.ebay.co.uk/itm/Ultra-Racing ... SwmrlU1OTa
Beedub
Post by Beedub » Tue Jul 03, 2018 11:30 pm
This has been happening for ages, this is one of many ive seen reported, ive had a strut brace and shock tower reinforcement on my car for most of its life and id like to think this has negated some of the twist those braces may experience ( more the SB) So far so good tbh..... imo the SB is cheap insurance as it created the triangle of braces leading to a stiffer platform. FWIW most the car i see this happen to are track type suspension z4ms.... not really the stock stuff...
Mangozac
Post by Mangozac » Wed Jul 04, 2018 12:36 am
Got a pic of your shock tower reinforcements, Beedub?
Beedub
Post by Beedub » Wed Jul 04, 2018 6:24 pm
ill take a look and see what i have
FD3S
Post by FD3S » Fri Jul 06, 2018 9:19 pm
Beedub thanks for the answer.
bumpy roads here might be an explanation, because I never track the car and I still have the stock suspension.
FD3S
Post by FD3S » Fri Jul 06, 2018 9:22 pm
Thanks srhutch looks solid and serves all the needs at once.
TomK
Post by TomK » Fri Jul 06, 2018 10:36 pm
If you had a normal Z yes, but these won't fit the M, oil filler cap gets in the way iirc.
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, APs, RS-29s, Apex ARC-8, AD08-Rs, Bilstein B12, Turner arms & RTAB limiters, Vibratec mounts, Rogue pulleys & RSMs, Sparco carbon w/ 6 point, CDV delete, UUC ssk, M5 gearknob, oem strut
