3.0si to M
OnlineR60BBA
3.0si to M
Might be worth getting an oil analysis done before you spend big money on a con rod bearing job.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- tomscott
3.0si to M
You cant have the bearings checked. If you go to the effort to have them checked you might as well have them replaced as they are quite a job to get to.
The bearings themselves are cheap its the cost of the labour. This is why I would suggest getting a few things done in that general area, engine bolts, engine mounts etc as it means you wont have to pay for a mechanics time to do this again as they are all in the same area.
You can have an oil analysis to check for metal and that will tell you what is wearing.
What you have to be aware of is that it wont show the entire life of the bearing just a small snapshot in that space of time since the oil was changed. Its a good idea to get it done after an oil change in the service schedule, say the 2 yearly it will give you a better idea over an amount of miles, than say having the oil changed then 6 months having it analysed because its not a long enough to show wear unless you have done the allocate 14k in that 6 months which is fairly unlikely.
Anyway its not that much of a worry I would have it done if your car has over 100k just for your own piece of mind and as preventative maintenance. They are designed to take the hammer but they are wearable items.
3.0si to M
Wise words Tom, an analysis which being a good indicator, is indeed only a snap shot. It is true that its only sense to change them whislt they are being inspected - my indy suggests race shells.
My car has a 100k so this is something I will save up and get done next year before the car is put back on the road after winter. They are quoting 1k to do them so hopefully this is a sensible price.
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- tomscott
3.0si to M
1k sounds the right ball park, i would be inclined to get the rest done at the same time, saves time money and the car will feel far better on new mounts etc.
It depends really. As far as I know the tolerances are very small as it is. The Z4M got the updated bearings as these were the main issue of early E46 M3s and late Z3Ms.
I would be inclined to use the exact same bearings, there is a lot of information on third party bearings but there is also very little of long term information on them. Ive heard all sorts of pros and cons, its hard to determine what is reliable and what isnt.
At the end of the day these engines are very reliable with the original bearings and really if your car has got to 100k problem free... I would replace them like for like.
I dont really know what the benefit of putting race bearings is to a road car. Replacing them for OEM parts will also give piece of mind
Just my opinion obviously.
OnlineR60BBA
3.0si to M
Tbh,
If the car has done 100k and there is no proof of them being done before, I would get them done ASAP.
I believe the following garages are renowned for undertaking this sort of work, (it might be worth giving them a call to see whether you could get a better deal):
Munich Legends
ETA Motorsport
Redish Motorsport
CPC Amersham
Good luck
Munich Legends
ETA Motorsport
Redish Motorsport
CPC Amersham
Good luck
- tomscott
3.0si to M
There's not much point in scaremongering, lots of S54s have made much higher mileage without issue. Its something to have in mind but I wouldn't be fretting over it. There are very very few S54 failures on bearings, its usually a multitude of issues due to heavy use like track days etcR60BBA wrote: ↑Mon Jul 02, 2018 3:28 pm Tbh,
Munich Legends
ETA Motorsport
Redish Motorsport
CPC Amersham
Good luck
These cars are 12+ years old and in the 7 years ive been on this forum I can think of 3 examples of bearing failure, fairly sure 2 were used as track cars.
3.0si to M
I know of one that was cained to within an inch of its life, even when cold! As you've mentioned Tom, engines have had damaged bearings at 40k some tracked cars, fine at 150k. It's something to consider and worth doing that's for sure. The bottom line is they are a car that some owners don't have a clue about and who just put fuel in and drive.
Worth doing at some point that's for sure. .
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
OnlineR60BBA
3.0si to M
Advising someone to change their rod bearings because their engine has 100k on the clock is not scaremongering buddy.
The point is that Simon does not know how the previous owners treated the car. Whether they let the car warm up before giving full throttle or whether they used proper 10w60 oil.
There have been cases of full service history engine having worn rod bearings with just 28k on the clock. (Ofc this is rare) but the common consensus is that bearings should be changed around the 80k mark.
You’re better off replacing the bearings for peace of mind than taking a risk and potentially ending up with engine failure.
3.0si to M
.... and when would people recommend changing the cam bolts ? Also heard these can cause issues ,
- bmwaddict
3.0si to M
Have to agree with R60BBA here. It's a known weak point and it seems it's down to luck whether they go at a lower mileage or last 200k! Definitely sensible to change at around the ton mark if you don't know how it's been driven/warmed up etc before your ownership, I bought mine on 100k and got them done straight away, just for peace of mind. They were actually in very good condition but it's done and prevention is always better than cure.
£1k is a lot cheaper than an engine rebuild!
Currently zedless
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Previous:
'07 Ruby Black Z4MC
- tomscott
3.0si to M
It is worth having it done but ASAP, nope. As I said in my post. it wouldn't stop me enjoying the car until the winter.
Most have them changed and find they aren't close to failing, which is why its worth having an oil analysis. If its got good service history from BMW and specialists then why the wrong oil would be used is beyond me.
If the car has been abused then the bearings are just one item on the list of concern its not a fix all solution.
- mr wilks
3.0si to M
Re the rod bearings , lets not stir the hornets nest scaring a majority of owners who enjoy their ZMs for weekend treats & rarely see the rev counter over 5500/6K or speedo over the designated limits , for these owners even on high miles its nonsense to assume impending doom for their bottom end & id love to see a freshly replaced set inspected again after the first 12k / 15k covered ? Would they be unmarked ?
I would imagine each & every S54 no matter the miles or use would show signs of wear to some extent , there will always be worse case scenarios & id wager that those odds increase with dirty oil , cheap oil , wrong oil , low oil , high revving from cold but for me the biggest killer is extreme heat cycle from max speeds / max revs for prolonged time , Ie trackday use for the ones that aren't prepped properly with fresh oil beforehand , correct level & knowing when you've cooked it .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3.0si to M
Not planned anything yet although I’ve heard a bit about this,it’s done 50.000 miles so shouldn’t be knackered just yet but out of interest where is a good place and how much roughly
3.0si to M
Out if interest Mr Wilks I spoke to the previous owner prior to picking th3 car up and I think he sed it’s due an oil change,how much oil does it take and a good oil recommendation as it’s in the garage now until I return from Le man classic
- mr wilks
3.0si to M
6 litres & the only stuff id use is Millers CFS 10w60 , https://www.ebay.co.uk/itm/Millers-CFS- ... Sw32lYnap6
i know many think oil is oil as long as correct grade is used but imo they are far from all the same in terms of cold start qualities & resistance to extreme heat .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
