Headlight woes
"M" Specific discussion
Andp
Headlight woes
Post by Andp » Wed May 09, 2018 12:44 pm
Having just replaced both the angel eyes with BMW oem complete units , as one had failed, now I have one Xenon bulb
going off and on ( mainly off! ) :headbang:
I had the work done at a local garage as I know the job is fiddly.
Shall I now buy 2 replacement bulbs, is it definitely the bulb and not anything else?
( loose connection/ igniter ).
And, is it a good idea to replace seals at same time, as condensation is affecting the units?
Any thoughts/advice gratefully received!
Z4MR Titanium
bmwaddict
Headlight woes
Post by bmwaddict » Wed May 09, 2018 1:01 pm
What units are you referring to? The E85/6 just have a small bulb in a plastic holder that lights up the angel eye. Try swapping the xenon bulbs over to see if it still does it on the other side and you'll know if it's the bulb, or possibly the ballast.
Currently zedless :(
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
zmaster007
Headlight woes
Post by zmaster007 » Wed May 09, 2018 1:04 pm
Switch the bulbs from side to side - see if the fault follows (if it follows then its probably the bulb). If the fault stays the same, do the same with the igniters. If the fault stays, it's likely to be the ballast.
Steps here: viewtopic.php?f=12&t=104600
Spaniarduk
Headlight woes
Post by Spaniarduk » Wed May 09, 2018 3:17 pm
Are the headlight rubber seals available to purchase desperately??
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo 🕺💃
bmwaddict
Headlight woes
Post by bmwaddict » Wed May 09, 2018 3:20 pm
Spaniarduk wrote: Wed May 09, 2018 3:17 pm Are the headlight rubber seals available to purchase desperately??
I believe they are only available with the rear covers.
Previous:
'07 Ruby Black Z4MC
Andp
Headlight woes
Post by Andp » Wed May 09, 2018 5:46 pm
Many thanks for replies.
Will swap bulbs first.
I take it this is easier than changing angel eye bulbs? :D
Z4MR Titanium
bmwaddict
Headlight woes
Post by bmwaddict » Wed May 09, 2018 6:33 pm
Andp wrote: Wed May 09, 2018 5:46 pm Many thanks for replies.
Angel eyes are a bit easier!
Turn wheel to the outside or remove, remove cover in wheel arch, remove light rear cover, remove spring clip off igniter, twist igniter anti clockwise til it clicks and pull away, remove bulb metal spring clip and pull bulb out. Getting the new one in and to sit right is the challenge!
Previous:
'07 Ruby Black Z4MC
