Springs
"M" Specific discussion
bjd
Springs
Post by bjd » Tue Apr 10, 2018 7:38 pm
Hi guys,
So long story short, I thought I heard a funny noise. I didn't think of it at the time but then it dawned on me that it could be the springs that have broken.
I looked at the rear and on one side i could fit three fingers between between the tyre and the wheel arch and on the other side I could fit two. I'm thinking it's the springs but I can't get under to see. Is it likely to be anything else?
I'm guessing this won't be covered by the BMW extended warranty so I was thinking of fitting some Eibach pro springs. Is this the way to go?
I have a trip planned so kinda need to move quickly on this. How much should I expect to pay a garage to fit these?
Thanks very much for any help/advice!
2007 Z4MR with all the toys and gadgets!
Pastry
Springs
Post by Pastry » Tue Apr 10, 2018 7:44 pm
That’s good timing, I fitted some H&Rs today which lower the car by 25ish mm I believe but ride quality doesn’t seem to have suffered at all :thumbsup:
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
ben g
Springs
Post by ben g » Wed Apr 11, 2018 1:50 pm
There should be a small difference between left and right ride heights anyway, so I'd say you're better off removing the wheels, taking out the shock bolt and popping the springs out. Takes about 10 minutes per side to have a proper look.
bjd
Springs
Post by bjd » Wed Apr 11, 2018 2:03 pm
Oh really? OK. Maybe I'm just imagining there's a problem ;-)
Got an MOT next month so my local garage has said they will check it free of charge. Better safe than sorry and all that jazz.
srhutch
Moderator
Moderator
Springs
Post by srhutch » Wed Apr 11, 2018 7:23 pm
bjd wrote: Tue Apr 10, 2018 7:38 pm Hi guys,
If the spring has snapped it will be covered under Bmw warranty.
dannytheduck1985
Springs
Post by dannytheduck1985 » Sat Apr 14, 2018 1:21 am
srhutch wrote: Wed Apr 11, 2018 7:23 pm
Quite shocked bmw warranty a model that is 3 years off becoming a classic (obviously the early cars)
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
