Vanos rebuild
- Argenta
Vanos rebuild
Yoyoyo, where do one find the correct parts for a good price?
Been looking around it seems like a good deal buying all S54 related stuff from BesianSystems, then cambolts etc (rest of the stuff) from Hack Engineering. Or..?
Also I’ve only found DIY guide’s on the M3, tho I’m sure on our cars the radiator frame is in the way..
Is there a Z4M guide anywhere?
- Ducklakeview
Vanos rebuild
i6 automotive or XKR8 systems is where I get my VANOS kits from.
Mike
Mike
- AndyBeech
Vanos rebuild
Give Ben at Hack a shout, knows his stuff when it comes to the S54 VANOS. Besian has a guide on the website. Bear in mind you'll need various other tools to do it properly, timing cams etc.Argenta wrote: ↑Wed Jan 17, 2018 4:41 pmYoyoyo, where do one find the correct parts for a good price?
Have you got specific VANOS issues? I've spoken to various specialists, some rate Besian stuff....some say stay away and re-do with BMW parts....I would certainly do some reasearch before commiting to one way or another...I ended up paying Steve (MR Vanos) to give me a whole new recon unit eventually...£1000 odd all in....
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
- Ducklakeview
Vanos rebuild
Any chance you could elaborate a little? I appreciate you may not want to name names but this is the first i've heard of any 'stay away' comments regarding beisan stuffAndyBeech wrote: ↑Wed Jan 17, 2018 5:10 pm
RUBYIMOLACARBON
- AndyBeech
Vanos rebuild
Nothing bad or naming names needed. I had my own issues which probably were partially my own fault for letting too many separate garages have a bite at fixing various issues that came up, all unrelated to each other or separate, I'll never know. It would take me an age to write up my full VANOS experience....in a nutshell, mine was a total PITA for whatever reason that ended in an incurable whirring sound from the unit, so that was basically scrap in the end.beanie wrote: ↑Thu Jan 18, 2018 1:34 pmAny chance you could elaborate a little? I appreciate you may not want to name names but this is the first i've heard of any 'stay away' comments regarding beisan stuffAndyBeech wrote: ↑Wed Jan 17, 2018 5:10 pm
If I was going to touch the VANOS again though, for any issues, I would just get a recon one fitted by Mr Vanos (or other) and have done with it. You know what you're getting, the unit is tried and tested and it has a warranty, job done. As far as I'm aware, he recons units with all original BMW parts, and no anti rattle kits etc. take from that what you will
I'm certainly not saying stay away from Besian, just like I say, do your research and weigh up the options. If you're doing it yourself, make sure you know what you're doing and yeah you can save a fair wedge. If you're getting a garage to do it, then parts and labour won't be that far off the cost of a recon unit with guarantee. You don't have that if you go the Besian route and have issues afterwards....which you shouldn't, but you never know.
- Argenta
Vanos rebuild
Thanx for your answers, I’ve decided I’ll go for a vanos filter + oil change first, and see the results. I don’t yet have that 2-3000rpm rattle.
As for MrVanos or xkr8 systems I found nothing much...?
Hack are out of vanos filter kits.
Ended up buying filter/o-rings from BMW.
- Fishy Dave
Vanos rebuild
I changed the seals on my 2.5 M54 without having to time the cams, is the S54 different in that respect?
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
- Ducklakeview
Vanos rebuild
Anti rattle rings are not needed with oem cams, only with aftermarket ones running aggressive lift profiles.
Mike
Mike
- AndyBeech
Vanos rebuild
Mr Vanos has a website - but I can tell you, change out of £1000 will be next to nothing. That does include labour and all associated parts / recon unit / takes your old unit / probably do valve clearances while he's in there if you ask nicely And the nice cushion of a guarantee for the VANOS unit.Argenta wrote: ↑Thu Jan 18, 2018 4:03 pm Thanx for your answers, I’ve decided I’ll go for a vanos filter + oil change first, and see the results. I don’t yet have that 2-3000rpm rattle.
xkr8, not heard of them when it comes to the S54. Hack and Besian are the main suppliers for our parts.
Filter and O-rings are best from BMW anyway so that's fine. What I would say is if you do it, just buy a new valve block sealing plate from BMW, it's only cheap and saves messing around cutting out the old rings putting new ones in...which personally I would highly not recommend anyway (at least for the valve sealing plate...). The other O-rings are good to replace though obviously.
Dave - If you do the whole procedure ie. cam bolts and unit fully off then it'll need the timing done for sure. Uprated cam bolts is probably the key part you want to do along with the oil pump disc. Lots of info on those (potential) failures.
Duck - Besian and Hack recommended them as part of their rebuild, but I would agree probably not strictly necessary unless you have the loud 'marbles in a can' rattle....
Vanos rebuild
The correct procedure is to use special camshaft and crankshaft locking tools so that the timing is never allowed to deviate.
Definitely want new cam bolts and either a redrilled oil pump disc (which is ultimately only a band-aid) or an improved aftermarket hub on the oil pump side.
My understanding is that Z4Ms are less likely to have VANOS rattle but either way the rattle isn't damaging?
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- Ducklakeview
Vanos rebuild
As above, the S54 requires the cam locking/timing tools when doing the Vanos, whereas the M54 doesn't - However the rest of the procedure is very similar to the M54. So I have to again say - £1000. feck.....
Mike
Mike
- Fishy Dave
Vanos rebuild
Ah, thanks all, learnt something there.Ducklakeview wrote: ↑Thu Jan 18, 2018 9:46 pmAs above, the S54 requires the cam locking/timing tools when doing the Vanos, whereas the M54 doesn't - However the rest of the procedure is very similar to the M54.
Corvette C6
Mazda RX-8 race car
Mazda RX-8 race car
- AndyBeech
Vanos rebuild
True that, my bad, was a few years ago since I got involved in the whole procedure! I had a load of pictures with the whole procedure at some point, probably about still somewhere (loads on the Besian website anyway). The rattle isn't damaging as far as I'm aware, I had a totally different kind of sound, probably bearing related in the end but at that the point cost of investigation vs a refurb was a no brainer. Warranty will last me and probably the next owner as well so least that parts covered.Mangozac wrote: ↑Thu Jan 18, 2018 9:39 pmThe correct procedure is to use special camshaft and crankshaft locking tools so that the timing is never allowed to deviate.
Yup a grand isn't cheap for sure, but it's about standard when you factor in M tax. Besian parts plus a specialist to fit is going to be around £600-700. The procedure might be similar(ish) to the M54, but there are more parts involved and that's where the cost is. If you got an all new VANOS unit from BMW (without fitting) it would be way way over the double the cost alone.
There's options and that's why I say do you're research if you're thinking of getting it done. Apart from Steve being sometimes difficult to get hold of (allegedly, I didn't have a problem personally), he's got a great rep for doing these and been doing it for years in the M community, he did my old E36 M3 back in the day. I didn't feel like I was ripped off, I would just rather have gone that route in the first place!
