Torque settings
Torque settings
Need the torque setting for the cam cover nuts on the s54 engine cover, the chrome ones. Also the nuts that attach the oem strut brace to the brackets. Not the brackets to the strut top. Cheers guys. Also where I can find the torque settings in the future.
Z4MC
- stevo///m3
Torque settings
Someone will link you to the “TIS” setting book/sheet shortly I should imagine. I think I’ve seen it on here before. Why did you have the cover off?
Stevo
Stevo
SOLD - '07 MCoupe-Sapphire Metallic-Imola leather-piano black
Previous: E36 Evo Vert
Current: ocean-going G31 estate
Insta: stevothecrab
Insta: stevothecrab
- AndyBeech
Torque settings
Not sure on the strut brace, but if you mean the nuts for the black M plastic cover, just tighten by hand lightly with a ratchet is more than enough (you'll know when), they only hold on that cover after all.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
Torque settings
The nuts that go onto the strut bolts are 28 n/m. No it’s the ones on the black that the cross bar goes onto.
Z4MC
Torque settings
Might take the carbon fibre cover off and replace with the original. Bought a brand new badge or the cover from bmw so going to put that off the carbon one onto the original. The carbon one has slight bubbling in the top layer doesn’t look bad but I want it to look perfect. If I do take it off the cover will be up for sale for cheap if no one wants it I’ll put it on the wall in the shed pubstevo///m3 wrote: ↑Tue Jan 09, 2018 6:48 pmSomeone will link you to the “TIS” setting book/sheet shortly I should imagine. I think I’ve seen it on here before. Why did you have the cover off?
Stevo
Z4MC
- TomK
Torque settings
Oil drain plug: 18 ft-lbs
Oil filter housing cap bolt: 24 ft-lbs
Banjo bolt (side of valve cover): 18 ft-lbs (25 Nm)
Spark Plugs: 16 ft-lbs (22 Nm)
Cam Bolts: 10.3 ft-lbs (14 Nm )
Chain Tensioner bolt: 32mm 51.6 ft-lb (70nm)
Cylinder head bolts: E14 22.1 ft-lb (30nm)/90 degrees/90 degrees (see explanation in thread)
Engine mounts: 37 ft-lbs (49 Nm)
VANOS filter bolt: 20 ft-lbs
Oil pan bolts - 8.8 grade - 89 in-lbs (10 Nm)
10.9 grade - 106 in-lbs (12 Nm)
Tensioner: 18 ft. lbs. (24 Nm)
Idler Pulley: 33 ft. lbs (45 Nm)
Harmonic balancer M12x110 bolts: 44 ft-lbs (60 Nm) then 50 degrees and 50 degrees
Plastic ///M cover over valve cover: 89 in-lbs (10 Nm)
strut tower nuts: 25-26 ft-lbs (35 Nm)
strut bar nuts: 18 ft-lbs (24Nm)
Torque settings
TomK wrote: ↑Tue Jan 09, 2018 8:33 pm Oil drain plug: 18 ft-lbs
Who’s the man?
TomK’s the man. Cheers dude. Where did u find them?
Thank you!
Z4MC
- TomK
Torque settings
lol, saved off some us e46m3 forum many years ago. I've double checked a few with tis and have no reason to doubt them.
Torque settings
And now they are saved in my phone!
On a different point would love to try and get as many of the m coupes together this year and twist tomscotts arm to do some photos. Mainly to drool over your intake! But to have them together just for a bit to get the photos in the history books!
Z4MC
Torque settings
I'd be interested in the cover if you're happy to post to Australia. Will send you a PM
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- Gustavo7
Torque settings
Just for the record, you can find all the torque settings you need, and then some, on the following file:
http://d.pr/f/17gLN
Credit goes to Florian (Flow) from M3F.
http://d.pr/f/17gLN
Imola Red Z4MC
- TomK
Torque settings
Wow, that is awesome! Thanks for posting.Gustavo7 wrote: ↑Sat Jan 13, 2018 4:02 pm Just for the record, you can find all the torque settings you need, and then some, on the following file:
http://d.pr/f/17gLN
- GuidoK
Torque settings
There are I think some small inconsistencies in that document.
For instance the torque angle on the bolts of the reinforcement plate under the engine is 90 deg, not 90deg plus 30 deg.
90deg + 30deg is only for cars that have an reinforcement cross, not a reinforcement plate. In the document it is picted with the plate.
At least thats how I understand the way bmw intended it.
I think the difference is in that the cross is much thicker (so that bolt might also be longer) and as they're stretch bolts it would take a bigger torque angle on that cross to achieve the same stretch force than with the thin aluminium plate (which has 2 bolts there also)
But its quite a big differenct to torque something an extra 30deg or not.
- TomK
Torque settings
Do you think the inconsistency is related to the different chassis (e46) or just that it's incorrect?
- GuidoK
Torque settings
BMW TIS has for the e46 chassis both the procedure for the reinforcement cross as the reinforcement plate.
Cross:
Picture of a somewhat more degraded version
e46 m3 with the plate at the underside:
Video of an e46 m3 underside (totally done up, a feast for the eye)
https://www.youtube.com/watch?v=zuz_shLxGcc
I have no idea if there are different verions with plate or cross or so (I dont even know if there are any e46 m3's with the cross, if not, it would be incorrect, otherwise an inconsistency I guess). All I know is that they need different tightening torques and thats what caught my eye, because its on the first page with pictures (I obviously havent checked the complete document, but on the first picture page there is an apparant inconsistency)
But the z4/z4m have a plate there, needing 59Nm +90deg on new bolts.
Cross:
