Car hibernation - flat patch tyre saver
- Spaniarduk
Hello everyone.
Question for all of you who hibernate your Z4s over winter. What do you use to prevent your tyres from developing the flat patches from standing for months on the same patch? I'm struggling to find a tyre saver pad that is open enough for the car's 65cm diameter wheels. Everything I've found so far is for tyres up to 20" (50cm) diameter. Like this pair:
https://rover.ebay.com/rover/0/0/0?mpre ... 2496940938
TIA for your comments.
José
José
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- Havard
Not sure if there are other options with those tyre saves but is there not a possibility of moving the vehicle regularly.
This may seem like madness but I park my car on a reasonably thick carpet so that absorbs some of the weight between the tyre and a hard surface. Whether this actually helps I am not sure but I started doing it after making a balls of painting the garage floor and the tyres seemed to bring the paint with them after a while being sat.
The carpet stops this happening, I assume it spreads the load slightly, just enough to stop the garage floor coming with me when I take the car out... .
H.
H.
How about these, you can clip two together
https://www.motorsport-tools.com/tyre-s ... ector.html
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I'd use axle stands to lift the car off its tyres completely or pump the tyres up to their max pressure.
57 Z4MC Interlagos blue, Champagne leather, Carbon Dash, SatNav, Bluetooth, Cruise Control, Logic 7, Heated Seats, Rear Park sensors, Isofix and airbag disable switch for the ideal family car
Now Sold and replaced with a M2
- 2dogs
Modern radial tires should do 6 months to a year with no problems.
Blue Z4MC - now gone
- Havard
- Grumpyowl
I do what it says in the owners handbook pump tyres up to 50 lb and have never had a problem.
- Spaniarduk
Slightly different to the ones i found, but still only stretching up to 50cm diameterfirebobby wrote: ↑Sat Jan 06, 2018 12:08 amHow about these, you can clip two together
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- Spaniarduk
That is starting to sound like the best option...
Volando voy
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
I have had this problem recently. A 600 mile Welsh trip didnt cure the flat spot.
Have just bought some Milenco tyre savers from ebay - £31 for 4 so good value, and have pumped to 40 psi to see if the tyres can be rescued, but will increase to 50 if thats what the handbook says.
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
2003 Clio 172 Cup
I’ve whacked mine up to 45psi in the past and it’s worked.
Hoping it works this year too as put new rubber all round before hibernation this year
2016 F82 M4 Comp Pack, Mineral White
2016 F56 JCW - GONE
2007 ZMR, Titanium Silver for sunny days
2012 N18 JCW - GONE
2007 3.0si Z4C, Stratus Grey, Amarone Leather - GONE
2013 520d F10 - GONE
2016 F56 JCW - GONE
2012 N18 JCW - GONE
