"Tapping" engine & maintenance
- Spaniarduk
Mine also sounds a bit 'clicky' in general. This is something that always obsessed me and worried me even though the car has only 27k miles. The other day i started it and stuck my ear right in on and around the engine block. I think i managed to locate the clicks and ticks from the admission side but no specifoc spot in particular. As if it came from difgerent spots, but all the same. I suddenly realised that my ear was hovering over the injectors! The electomagnets opening and closing each injectors. Something impossible to follow when you realise that at 1100 rpm (idle speed when cold) the injectors are firing in total 3300 times a minute! For peace of mind I also opened the oil filler cap. That allowed me to listen in for other ticks. Nothing at all. Smooth as cream. Also I stuck my ear onto the VANOS. It sounded a little rough for a about 15 seconds. I guess until oil finally got to the inners of it. It got noticeable quieter, not that it was alarmingly loud. Im only thankful me and my OCD-ness never got that stethoscope for Xmas
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- mr wilks
18 months since last oil change ? You really need to stand next to it when cold & warm to comment but If it were mine I’d be changing the oil for some quality stuff (Millers CFS 10w 60 my only choice) .
Who did the valve check service 8k ago ? Trusted or maybe not ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Does it get louder when you rev the engine?.
On idle that sounds like mine did.
Put a clip on of the sound when you rev. If it’s the bottom end bearings, the knock sound will make you cringe
84’ E28 Alpina B9
83’ VW B2 Passat CL
90’ Mercedes 300E-24
90’ Vauxhall Carlton GSI 3000 24V manual
85’ Opel Ascona Cabriolet
83’ VW B2 Passat CL
Last oil change 6 months ago/ 2k miles, last valve clearance check was 18 months. Done by a very reputable bmw specialist (Forza GB).mr wilks wrote: ↑Fri Jan 05, 2018 11:10 pm18 months since last oil change ? You really need to stand next to it when cold & warm to comment but If it were mine I’d be changing the oil for some quality stuff (Millers CFS 10w 60 my only choice) .
Will probably get an oil change done just because though. The car doesn’t get many miles.
2006/56 Z4MC now sold!
2015/65 F Type R Coupe AWD arrived!
It goes away when not at idle actually, can’t hear anything untoward at all when moving up the revs.dannytheduck1985 wrote: ↑Fri Jan 05, 2018 11:41 pmDoes it get louder when you rev the engine?.
Will try and get a video of some rev movement tomorrow though for clarity.
That’s a good signShineyT wrote: ↑Fri Jan 05, 2018 11:56 pmIt goes away when not at idle actually, can’t hear anything untoward at all when moving up the revs.dannytheduck1985 wrote: ↑Fri Jan 05, 2018 11:41 pmDoes it get louder when you rev the engine?.
84’ E28 Alpina B9
83’ VW B2 Passat CL
83’ VW B2 Passat CL
