I need some vacuum support
Hello members, i need some support. Last year i found one abandoned Z4 coupe & figure out to restore it in Z4M version. I use an engine from E46 M3 , change bearing ,water pump, pipes, oxygen sensors, vacuum lines, filter box , oil coolant radiator.... in 1 word - everything is changed with new OEM parts. I have just one trouble - E46 M3 have a fuel filter with vacuum regulator - Z4M doesn't have it ,but the vacuum line is still available. http://bmwfans.info/parts-catalog/E86/E ... _air_line/ - rear end of number 15 . Please somebody to support me - where's going another end of this vacuum line.
- Beedub
i will need to check but i think it goes to the brake booster setup.
www.topwrapz.com - Multi Award Winning - Detailing | Vinyl Wrap | Paint Protection Film Specialists |
I was looking pictures in google,but didn't see that vacuum going to brake booster. A lot of Z4M owners here, please somebody to check
I just had a look and it doesn't actually go anywhere - it's capped off! It was obviously easier to just cap off an E46 specific connection rather than manufacture a whole new vacuum rail
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Thanks a lot for that info!
Pictures and updates needed for this thread!
