Easiest way of fuel disconnect?
"M" Specific discussion
Argenta
Post by Argenta » Sun May 20, 2018 9:22 pm
Hi, is there an easy way to, shortly, disconnect fuel supply? (Or, ignition..?)
Car’s been standing for months & with newly changed oil/filter I’d just like to get some oil pressure up before actually starting.
I realize I may get a fault code but I just erase it later.
Adam D
Post by Adam D » Sun May 20, 2018 9:56 pm
Pull the fuse to the fuel pump usually. Sounds a bit overkill mind ;)
Silver Grey 2007 Z4MR which needs to be driven more :evil: :P :cool: :D :thumbsup:
Argenta
Post by Argenta » Mon May 21, 2018 5:14 pm
Of course, thanx.
Well. I’m oldschool, and with the notoriously fragile S54 maybe just aswell.. :)
ph001
Post by ph001 » Mon May 21, 2018 9:09 pm
You won’t really build up any oil pressure just by turning it over anyway. Just start it....will be fine.
Argenta
Post by Argenta » Wed May 23, 2018 7:42 am
I beg to differ, you normally do. ;)
(unless the S54 half-dry sump in some way makes it work differently..)
Thanx alot for the advice (fuses) - worked a treat! :)
ZAR4MC
Post by ZAR4MC » Wed May 23, 2018 8:12 am
Hey Bud,
Just out of interest, do you still remember which fuse/relay did you pull to kill the fuel pump? would be nice to know so i can do the same when starting my car after its been standing for a long time...
07 Z4 M Coupe - Sapphire Black/Imola Red
ph001
Post by ph001 » Wed May 23, 2018 11:46 am
Argenta wrote: Wed May 23, 2018 7:42 am I beg to differ, you normally do.
That's fine. I've got no problem with that. I could point you at a multitude of sources to assure you it isn't necessary but feel I'd be wasting my time. By the same token, pulling the fuse doesn't do any harm if you have the time and the inclination.
Argenta
Post by Argenta » Thu May 24, 2018 1:05 am
Right, I was answering your claim that you cannot build up oil pressure by turning the engine over by starter motor - you will/can.
(Great after engine rebuild/long standning periods etc).
The necessety is a different and debatable matter, however as I wrote, I’m extra causious with the tender S54. :)
ZAR4MC wrote: Wed May 23, 2018 8:12 am Hey Bud,
I found this map of the fuses which shows the base Z4 I think, the F19 is empty on the Z4M. So I pulled F33.
Actually when you open the fuse box you’ll find a little map of the Z4M fuses, so you can’t go wrong.
ZAR4MC
Post by ZAR4MC » Thu May 24, 2018 8:58 am
Thanks so much bud... My car didn't come with the Owners Manual so this helps big time...
