Not sure I've found all the features, but have visual display of PDC, auto zoom Nav, auto time adjust and a few others that need testing.markeg wrote:It works really well Stuart - integrated well with the SatNav (tried flicking between the two, worked fine) Can scroll through Playlists, Albums, Artists and Songs with ease - just need to get up to speed with the rest of it
Headsup Intravee II Ebay
- srhutch
- Moderator
Re: Headsup Intravee II Ebay
- Stuart Truman
Easy to fit?
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- VvrooomM
Auto door lock.
Tapatalking on my iPhone.......
Z4MC midnight blue with CSL's + VREDs, extd light sepang leather, folding mirrors, stubby aerial, retro bluetooth, prof nav, intravee ipod kit, storage and cup holders!!, laser LRC100, DSP hi-fi, storage and privacy.....is that it?
- markeg
On a scale of 1 - 10, pretty much a 2, if that (for frustration levels with trim removal). Easy connections at the back, and simple to store away next to the bluetooth module (also added some rubber matting to prevent any squeeks/rattles), most frustrating bit is removing the boot trim (I broke a couple of trim clips, so am ebaying replacements ). Fed the wire through the centre to the ash tray (which I have temporarily removed whilst I work out a better mounting clip for my iPhone 4s) which involved moving the passenger seat forwards and backwards a few times (electric seats being a definite pain in this instance) to get the wiring under the trim. Connected up the phone, switched power on and all worked first time!Stuart Truman wrote:Easy to fit?
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- markeg
How do you access the extras menu? Does it need a software load?srhutch wrote:Not sure I've found all the features, but have visual display of PDC, auto zoom Nav, auto time adjust and a few others that need testing.markeg wrote:It works really well Stuart - integrated well with the SatNav (tried flicking between the two, worked fine) Can scroll through Playlists, Albums, Artists and Songs with ease - just need to get up to speed with the rest of it
current: MB C-class
current: MB C-class
- srhutch
- Moderator
Unless you have the latest version you won't have the extras menu.
6.02-6409 is the latest I have which came with the extras menu.
- Dean
Could you link the trim clips as I lost a load doing mine and I can't seem to find the correct ones
Black 3.0si Roadster for sale
http://www.autotrader.co.uk/classified/ ... ?logcode=p
- markeg
Will do Dean - just waiting for them to arrive (ordered three differing types, always helps to have spares ) and once checked, will link the correct ones.
current: MB C-class
current: MB C-class
- Dean
Thankyou that's very kind
- Stuart Truman
I hope it's that easy! I just bought Daffy's kit that he was sellingmarkeg wrote:On a scale of 1 - 10, pretty much a 2, if that (for frustration levels with trim removal). Easy connections at the back, and simple to store away next to the bluetooth module (also added some rubber matting to prevent any squeeks/rattles), most frustrating bit is removing the boot trim (I broke a couple of trim clips, so am ebaying replacements ). Fed the wire through the centre to the ash tray (which I have temporarily removed whilst I work out a better mounting clip for my iPhone 4s) which involved moving the passenger seat forwards and backwards a few times (electric seats being a definite pain in this instance) to get the wiring under the trim. Connected up the phone, switched power on and all worked first time!Stuart Truman wrote:Easy to fit?
If you could post any pics of how you mounted yours I'd be grateful
- VvrooomM
Trim is way beyond a 2 until you have done it before.
- pvr
Having fitted 5 of these now, the trim varies from car to car for some reason. Some are dead easy, others are a real pain.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- markeg
will do Stuart but am in Moscow at the moment - will do at the weekend ?Stuart Truman wrote:I hope it's that easy! I just bought Daffy's kit that he was sellingmarkeg wrote:On a scale of 1 - 10, pretty much a 2, if that (for frustration levels with trim removal). Easy connections at the back, and simple to store away next to the bluetooth module (also added some rubber matting to prevent any squeeks/rattles), most frustrating bit is removing the boot trim (I broke a couple of trim clips, so am ebaying replacements ). Fed the wire through the centre to the ash tray (which I have temporarily removed whilst I work out a better mounting clip for my iPhone 4s) which involved moving the passenger seat forwards and backwards a few times (electric seats being a definite pain in this instance) to get the wiring under the trim. Connected up the phone, switched power on and all worked first time!Stuart Truman wrote:Easy to fit?
current: MB C-class
current: MB C-class
- Stuart Truman
That'd be marvellous. Enjoy Russia and the incredibly expensive, well everything really!
- markeg
Here you go Stuart, hope it helps.
Firstly fold the roof recess upwards (so the roof can’t be taken down). This frees up the space so the carpet trim can be moved. Remove the hardboard battery cover, then fold the remaining floor carpet back towards the rear of the boot. I didn’t bother removing these clips as I didn’t want to damage them (and they are very fragile)
So now the boot looks like this:
Next I threaded the emergency centre console release button on the rear bulkhead back through the carpet and the underlying soundproofing.
I now removed all four retaining clips, two on the left and two on the right, from the sides of the rear bulkhead carpeting
Be very careful with these as they are fragile and easily break. Mine snapped, and I looked at sourcing replacements from eBay. I couldn’t find any and ended up buying some from Sopers. They only cost a couple of quid for four: item numbers are for spacer bush (51478189959) and blind plug (51718137323) which both come in packs of four.
Now gently tweak the carpet from behind the plastic trim – its only folded behind there so should come out fairly easy
The rear carpet and soundproofing should now be easily pulled upwards to gain access to the leads and bulkhead
I held the soundproofing and carpet up by use of rubber-faced clips
I mounted the Intravee and KCA module onto the rear bulkhead by using the thick number plate pads from Halfords – stick well and ensure that the modules don’t rattle against the metalwork. Side view and close up of the leads:
The USB lead is attached to the Intravee and fed through the side so I don’t have to remove the carpeting again to provide updates
I’ll post the threading through to the main cabin and my (somewhat Heath Robinson) mounting affair for holding the iPhone later this weekend.
current: MB C-class
current: MB C-class
