I think the part number is different for the M version.Calps wrote: ↑Tue May 25, 2021 8:25 pmThat's interesting, particularly that it removed some, but not all of the lights.
I have the trifecta of lights and error code 5E30, which I'm really hoping the 34526764018 part which I have (that supposedly works) actually does the business. Will hopefully have an update within the next fortnight.
WANTED DSC Sensor. Part No. 34526769174
Z4MC, Silver/Grey, Imola Red Leather, Sat Nav, Heated Seats, DSP, Intravee, Stubby, ZHP, Gruppe M, CDV, Bilstein B12's, Vibra-Technics engine mounts.
From my messages, the fault code present on mine is 5E34 if that info is worth anything to you.
Z4MC - Monaco Blue w/ Imola Red interior.
Ah, well that would make a load of sense! ThanksMuckinonthesofa wrote: ↑Wed May 26, 2021 6:40 amI think the part number is different for the M version.Calps wrote: ↑Tue May 25, 2021 8:25 pmThat's interesting, particularly that it removed some, but not all of the lights.
Hey Calps, did you successfully fit that older sensor ?
Same issue here; wet carpets, lights trifecta, dead speed sensor (34526769174)
Z4 2008 Roadster 3.0i error code 5D8C (also seems to have triggered related codes before dying: 5E19, 5DC3, 5DA3, 5D93, 5DF4)
Anyone else successfully fitted the 34526764018 as a replacement (vs original 34526769174) ?
34526769174 can't be found for cheap;
34526764018 : common and cheap on Ebay
Will probably setup INPA later this year but I understand that the sensor shouldn't require reprogramming once swapped, right?
Will post a similar question on the other thread as well,
Thanks!
Thanks!
- Calps
Hey 123qweasd,123qweasd wrote: ↑Wed Aug 25, 2021 1:58 am Hey Calps, did you successfully fit that older sensor ?
Thanks!
Unfortunately haven't fitted it yet. I've noticed that when the weather is good, the lights go away (presumably because any moisture dries up), and so the mantra out of sight, out of mind has taken over. I'm expecting the damp weather of late will have a nice surprise waiting for me when I take it out again though, so this will get bumped back up my to do list, along with a door membrane inspection to understand how water is getting in. (Ideally if I solve that, I may not need to change the part at all).
Sorry I can't be of more help at this time, but I'll update back here once I complete it.
Calps
MelZ: Black Sapphire Z4C
Thanks, keep us posted
pulp wrote: ↑Tue May 25, 2021 6:46 pmThanks. Yeah I have already replaced the sensor once but not with the correct part, and it reduced from the three lights on the dash to just the orange handbrake light and one error code.Muckinonthesofa wrote: ↑Tue May 25, 2021 6:42 pmI had the 3 lights and it was the DSC/Cluster sensor.
I don't have one but I can confirm this is the correct part number, I had to replace mine recently. It is quite confusing establishing the correct part number as some sites say the cheaper part is compatible but it is not.
The conflicting advice is throwing me off too!
Any update pulp?
I have the same issue here ( installed 34526764018 in a post facelift car (original installed Part Number was 34526769174)
And still have the yellow brake light on.
Wondering if it actually works and the brake light is just an annoyance or if it doesn't work at all and needs to be replaced with the (way overpriced...) Original part number...
let me know, thx
- steve_naive
I sprayed the wiring to the ABS/DSC module with contact cleaner, cleared the code and it went away.
Top left of the engine bay iirc.
Solved!!! So took my car out of storage today and fitted DSC sensor, very quick and easy task, 3 x lights extinguished immediately
So did you install 34526764018 in a post facelift car? (original installed Part Number 34526769174)
Still have the orange brake light here....
No i managed to pick up a secondhand one for 90e with correct 34526769174 part number like for like.
Very sorry for the late reply on this. I did have to use the original part in the end to clear all lights on the dash, even after trying to flash the whole system.
Thanks for the reply, seems like you can't get rid of the brake light with the older unit. Will see if If I can live with it or will look for a newer unit at a decent price. Cheers,
- enuff_zed
Sorry this is a very late reply, but I have a spare of the one you need, if you do still need it?
Thx for your reply,
how much would you want for it?
You can pm me, thanks!
