WANTED E85 / E86 ISOFIX Passenger Seat Bracket
- bakes100
Hi,
I am looking for an ISOFIX bracket to fit the passenger seat base frame of an E85 / E86 Z4.
If anyone has one please let me know.
Stuart
Stuart
2006 BMW Z4M Coupe - Sapphire Black
2007 BMW Z4M Coupe - Silver Grey - GONE
Just to check - do you have the button to switch of your passenger airbag? Or plan on fitting this?
If not it wouldn't be recommended to fit a child seat even if you do find an isofix bracket.
Used to work at a baby shop, have this stuff drilled into me
Car Photographer based in Scotland - Co-owner of keepitclean and run cleanfest - Scotland's Premium Car Show
Montego Blue Z4 Coupe
- bakes100
Hi Mike,
Yes plan on fitting the retrofit kit for disabling the passenger airbag
Thought you would have been - just couldn’t not ask best of luck finding an isofix bracket anyway!
Aren't the brackets welded to the frame ?? I'm sure when I changed my seats to M sport, the brackets were part of the frame
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- bakes100
I was under the impression it was a bolt on bracket based on previous threads on the forum, however you can’t buy it separately from BMW.
- bakes100
You don't happen to have a photo of the bracket before you fitted it do you?ErrErrminator wrote: ↑Sun May 31, 2020 9:48 amI can confirm that it is a bolt on piece, having fitted one to my E85 non-M sport passenger seat.
I did have, but can’t find it now. I had a look online but can’t find a Z4 specific diagram. This one is of a 1 series I think, but the arrangement is much the same. It’s a fiddly job to get to the bolts, but you basically undo two bolts at the back of the seat base frame, remove the cross brace shown (7) and replace it with the ISOFIX cross brace (circled in red).
I don’t think you can buy the part on its own from BMW without buying the whole seat base. I got mine on an exchange basis from a member on here who answered my request.
- bakes100
BUMP - Still after an Isofix bracket if anyone has one.
- bakes100
Still looking for one of these !
- kis
Your best bet might be to buy a whole used passenger seat with the bracket. Alternatively contact breakers to see if they would sell it to you seperate?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- bakes100
Yeah I have tried breakers however the bracket would need to be replaced with the non-ISOFIX bracket to retain the integrity of the seat, I might have to go down the route of purchasing an entire seat.
