In the course of removing and replacing the centre console on our coupe have damaged this clip that secures the gearshift surround. Its shows as being available only as part of 51167158473 gearshift cover, but naturally I'm not inclined to fork out 61 pounds just to get the clips that come with this item, and try as I have cannot see these individually, on Real OEM. Clip measures 15mm oal x 7mm wide and described as s shaped, with two spurs to attach.
Attached a couple of pix, happy to pay for post and whatever, someone may have a couple tucked away somewhere. All advice taken on board and thank you for reading Bill.
WANTED NOW FIXED Pesky console clips
- IMG_2236.JPG (38.96 KiB) Viewed 460 times
- IMG_2233.JPG (34.06 KiB) Viewed 460 times
