All sorted got the independent I use to fit it and also check the suspension and break discs.
He confirmed the suspension looks fine but could probably do with the shock absorbers refreshing on the basis it looks like the originals are still fitted but most of the other components have been updated - he did say it looks like lower springs have been fitted and recommended looking at the Bilstein B12 kit
Again the discs and pads are fine but suggested updating the discs as they look original and are well worn
Appreciate your thoughts on both if you have any recommendations From when you had the car
