WANTED Drivers side headlight casing (can be smashed)
I want to try and steal the plastic bracket that holds the rear plate off the back so I can weld it onto my headlight
Are you sure the broken lug is not the one for which BMW sell a repair kit?
e.g. item 13 below: https://www.realoem.com/bmw/enUS/showpa ... Id=63_0758
Chris
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
- kis
Speak to JINGLE, he's got a few headlights in pieces. I believe one set was in poor condition so is being used for parts...
viewtopic.php?f=2&t=110745
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Here's the broken bit
- broken ta b.jpg (326.08 KiB) Viewed 756 times
- JINGLE
Hi mate I’ll double check 1 of the broken 1s I have, I know 1 defo has a broken rear but not sure about the other, if it’s the right 1 for you I’ll happily send for free
- JINGLE
Before I get home and have a chance to check, are you sure it’s letting in moisture? When I had all mine cut open and apart checking over all the fixing lugs etc and noticed 1 of mine was broken, when the metal clip (part 6 in the above drawing) it holds it pretty tight and square so may be worth giving the seal a good clean and hopefully that will help
Deffo leaking from somewhere, that’s the only place o can think it’s coming in from as I’ve had the bumper off and stuck silicon all around the lamp as well as a bit of sealer around the lip of the seal.
I’d bought a replacement rear cover thinking that would solve it, such a pain in the backside haha
JINGLE wrote: ↑Mon Dec 03, 2018 6:57 pm Before I get home and have a chance to check, are you sure it’s letting in moisture? When I had all mine cut open and apart checking over all the fixing lugs etc and noticed 1 of mine was broken, when the metal clip (part 6 in the above drawing) it holds it pretty tight and square so may be worth giving the seal a good clean and hopefully that will help
- JINGLE
Hi mate, unfortunately both are broken so I can’t help. Sorry I can’t help
- IAmOrion
I may actually have one - I can't check until Wednesday night though as I'm not around... will update you soon OP
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- JINGLE
I have a spare driver side facelift headlight with intact bracket. It is, or rather was, a black internal style xenon, but has been plundered for parts.
I would like to remove and keep the lens and the clear indicator hockey-stick, but you’d be welcome to the bare case if it’s of use to you.
How urgently do you need it? I could probably get the bits I want off of it at the weekend, then send you the case next week if you cover the postage cost.
- IAmOrion
Ilogik, I have a drivers side & passenger side you're welcome to. If you wanted I can cut off the bit(s) you want with some excess so it's easier to send... or you're welcome to collect as is from Cambridge CB22. Free of course, they were in my "To take to the dump" bin
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Hi both sorry for late reply. If you could cut me a chunk off Iamorion I’ll ask my body shop if they can plastic weld it back on.
Ermintor, no real rush and yeh if I could just get the plasti bit of the welding fails I might see if my body shop can split both lights, paint the internals black and then glue it back. But that would be w far bigger job .
Quite like the idea of black insides on mine.
Let me know how much postage is
