WANTED E85 / E86 offside headlamp washer.
- ph001
My drivers side headlamp washer has decided to p*ss water out all over my garage floor. Checked pipes and connections last night and it's defo the washer body itself that is leaking. There appears to be some bits of blue coloured silicone type sealant fragmenting out of the body and also around the washer jet head. I'm guessing this must be some kind of internal seal that has failed and fallen apart.
Just wondering if anybody has a spare kicking around their garage they want to sell before stumping up 70 of my hard earned pounds to BMW
I believe I do. Pm me an offer please.. Cheers
Are they sided?
I need a nearside!
- ph001
I did wonder about this but they defo have a different part number:
6167 7057 452 - drivers side (offside)
6167 7057 451 - passenger side (nearside)
I can't see the fixings being any different so must just be the spray pattern or something. Have pm'd you
- kis
So do I
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Hmm. I thought they'd be the same. The difference must be very subtle so I'm guessing the nozzle isn't aimable? There isn't a part number on the part that I can see.
I thought maybe I could sell one then have a spare had they been identical. Not sure at the moment? Sorry
- ph001
Understand. If you have two to look at maybe you could cast your eye over them both and see if you can spot any differences. Must admit, can't see the spray pattern being very critical so would be good to know!
- kis
From what I can tell, the RIGHT unit when upside down has the hook on the left.
The LEFT unit when upside down has the hook on the right.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- ph001
***deleted***
- ph001
...buggered if I can spot any difference!
- iCharlieHolder
This might sound odd - but can I have your old busted one?
Thanks!
Thanks!
Z4M Roadster
- ph001
I’m planning to cut the bastard open and see what actually fails in true engineering fashion unfortunately!
- iCharlieHolder
Haha! no worries!
If this bit survives the butchering, I'm very much in need!
Many thanks!!
Many thanks!!
Z4M Roadster
Do a search on here as I just bought two of those for around £11.
2007 z4 coupe 3.0 si Carbon Black
