SOLD AP-Racing 6 Piston Kit CP5575-1004 Calipers, Pads & Discs
- X-S-Z
AP Racing CP5575-1004
http://www.apracing.com/product_details ... k_pad.aspx
The calipers have around 12,000 miles on them, not heavy use. In perfect working order when removed from car (BMW Z4M) before sale last month. The discs are just use-able, they have been an advisory on previous MoT but not a fail point. The pads are new Pagid PS29 with around 2,000 miles on them.
The set is around £2,665 new, brake pads are around £250 for the set.
https://www.vagbremtechnic.com/ap-racin ... 5575-1004/
Looking for £1,250 o.n.o. with buyer collecting or arranging postage.
Current: Imola red Z4MR
Previous: Z4 3.0i SE, 118d SE
Good luck with the sale, these shouldn’t be around for long
Just clarifying, as I’m sorted myself
As this is an e43 M3 specific kit, can you confirm these fit a standard Z4M front wheel, without any mods/spacers/etc., as I’ve seen some warnings on M3-Cutters/Z-Post about small differences between the 2 kits (different disc & bracket part numbers).
For reference, the Z4M kit is CP5575-1010.
- hopz121
Any pictures?
Where are you located?
also can you confirm this is defiantly the E46 M3 kit or is it a Z4M kit?
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- X-S-Z
Correct they are M3 ones, not Z4 ones.mmm-five wrote: ↑Tue Jul 10, 2018 12:41 pm As this is an e43 M3 specific kit, can you confirm these fit a standard Z4M front wheel, without any mods/spacers/etc., as I’ve seen some warnings on M3-Cutters/Z-Post about small differences between the 2 kits (different disc & bracket part numbers).
- X-S-Z
Pictures to follow... (I am out of country but my friend has them and will send me shortly then I'll post)
The brakes are located in Falkirk just now (I am not).
Yes, 100% E46 M3 kit.
- BMWZ4MC
I’m running an E46 M3 AP Racing BBK front and rear on my Z4MC. The fronts need a 2mm washer under each of the caliper mounting bolts, the rears fit without shims.
I bought my BBK from Fishy Dave. He sought and was given approval by an engineer at AP for the use of washers as shims for this purpose when he purchased the BBK.
No wheel spacers are required with 18 or 19 inch wheels.
GLWTS
GLWTS
S2000 GT - gone
- X-S-Z
Thanks! In this case I must also have the washers lying with the box of bits... when the photos arrive it'll confirm. So they're supplied ready to fitBMWZ4MC wrote: ↑Tue Jul 10, 2018 1:36 pm I’m running an E46 M3 AP Racing BBK front and rear on my Z4MC. The fronts need a 2mm washer under each of the mounting bolts, the rears fit without shims.
GLWTS
- BMWZ4MC
My front calipers came with eight identical washers, four sit under the heads of the four caliper bolts whilst the other four washers are the shims.
S2000 GT - gone
- Fishy Dave
Bear in mind that the M3 disc bells are slightly different too. I had a local company make me a 2mm shim to fit between the bell and the hub, otherwise the disc is too close to the bottom ball joint. This solution worked just fine up to the point I bought Z4M specific bells from Reyland.
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
- X-S-Z
Ah yes that reminds me, there was a 2mm spacer under the hub... easy enough to get machined up.Fishy Dave wrote: ↑Tue Jul 10, 2018 3:07 pm Bear in mind that the M3 disc bells are slightly different too. I had a local company make me a 2mm shim to fit between the bell and the hub, otherwise the disc is too close to the bottom ball joint. This solution worked just fine up to the point I bought Z4M specific bells from Reyland.
This was the reason for my query...
Going into a purchase fully informed is fine, but you really don’t want to buy a kit, arrange to get it fitted, and then find out it won’t fit because you need something machined!
- hopz121
Interested after seeing images
- bradz
Great price!
Interesting about fitment too, Dave how much were the bells alone?
I just bought an e46 m3 for it's full set of Ap's, and a few other goodies
Z4M Coupe, E92 M3, E46 M3 Track car
- TomK
Unfortunately about £240 I think.
- Fishy Dave
I can't remember the exact price but that does sound about right, they were cheaper than going direct to AP.
Corvette C6
Mazda RX-8 race car
Mazda RX-8 race car
