Wanted 224s or CSLs
- derin100
Wanted 224s or CSLs
I have just taken a couple of the wheels of my car to check the measurements stamped on the inside.
Just to clarify, the wheels on my E85 Z4M are the following:
Rears = 19" 9.5J ET38 and also had a 2.5 mm spacer fitted
Fronts = 19" 8.5J ET36 no spacer
Hope that helps?
Hope that helps?
E85 3.0Si Silver on Black (Gone and will be missed)
E85 M Roadster Silver Grey on Black
E85 Alpina Roadster S Toledo Blue on Black
- derin100
Wanted 224s or CSLs
derin100 wrote: ↑Thu Feb 01, 2018 6:15 pmI have just taken a couple of the wheels of my car to check the measurements stamped on the inside.
Hope that helps?
I'll just go and re-check the tyre dimensions as well!
- derin100
Wanted 224s or CSLs
Rear = 265/30/19derin100 wrote: ↑Thu Feb 01, 2018 6:16 pmderin100 wrote: ↑Thu Feb 01, 2018 6:15 pmI have just taken a couple of the wheels of my car to check the measurements stamped on the inside.
Hope that helps?
Front = 235/35/19
- mr wilks
Wanted 224s or CSLs
The rears would usually be et 27/30ish for M cars so possibly intended for E90 ?derin100 wrote: ↑Thu Feb 01, 2018 6:15 pmI have just taken a couple of the wheels of my car to check the measurements stamped on the inside.
Hope that helps?[/
The rears 9.5j et 38 will fit any non M Z4s fine ( & clearly Ms too but ideally want a wider spacer than 2mm ( 10mm better )
The fronts , , , 8.5j et36 could divide forum opinion here "possibly" ok on a roady with 225 35 tyre & if car not significantly lowered , maybe a slight rub on Si coupe when driving spiritedly ? they are borderline fitment numbers imo as i know members who have had rubbing with 8.5 et 38 19s & 8j et 35 19s until tyre sizes were reduced to a slight stretch
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Attilio
Wanted 224s or CSLs
Hello derin100,derin100 wrote: ↑Thu Feb 01, 2018 1:43 amI have a set of those 19" CSL style wheels in Hyper Silver on my Z4M. They are effectively brand new with new tyres on them (the brand is Event...which I've never heard of so can't say yay or nay on them). They were fitted brand new by the dealer I bought the car from. They (both the wheels and tyres) have only been driven the distance from Ripon (where the dealership was) to Lincoln (where I am) which Google says is 103 miles plus about 4 miles...because that's the distance I have only ever driven my Z4M.
I have some refurbished 224s to go on my car but don't have the spare cash to buy tyres for them. So if someone wants to make me a decent offer for the 19"s...?
any chance of some pics? I might be interested in those CSL reps... thanks!
Z4M Coupe, Interlagos blue, black leather, piano black, stubby, OEM CSLs, evolve intake, cup holders...pretty much stock
2019 Toyota Corolla hybrid 2.0L - new daily drive
- derin100
Wanted 224s or CSLs
If you could pm an email address that would be easiest for me ( as I don't seem to have much luck posting pics to this forum ) I could then email you pics.
- derin100
Wanted 224s or CSLs
mr wilks wrote: ↑Thu Feb 01, 2018 6:27 pmThe rears would usually be et 27/30ish for M cars so possibly intended for E90 ?derin100 wrote: ↑Thu Feb 01, 2018 6:15 pmI have just taken a couple of the wheels of my car to check the measurements stamped on the inside.
Hope that helps?[/
Thanks Mr Wilks
- derin100
Wanted 224s or CSLs
Oh! Should have mentioned they come with a set of different bolts too (? longer?) that have the 'Hex' on the inside of the bolt and the specific tool for these bolts.
- Tyreman
- derin100
Wanted 224s or CSLs
Replied
- derin100
Wanted 224s or CSLs
I've managed to find the exact ones that I have on EBay which must have been where the dearlership I bought my car from got the wheels:
https://www.ebay.co.uk/itm/19-BMW-CSL-S ... Sw0t9U16-i
That might help?
That might help?
- derin100
Wanted 224s or CSLs
I've managed to find the exact ones that I have ( in terms of style and make) on EBay which must have been where the dearlership I bought my car from got the wheels:
That might help?
That might help?
- Tyreman
Wanted 224s or CSLs
In an attempt to clear up the offset thing on a 3.0Si coupe I've received specific size recommendations from CM Wheels........
19x8.5 et38
19x9.5 et40
We have Hyper Silver, satin gunmetal and Hyper Black
Tyre sizes 235/35/19 Front
265/30/19 Rear
Hope this helps
19x8.5 et38
19x9.5 et40
265/30/19 Rear
Hope this helps
- derin100
Wanted 224s or CSLs
So tyres exactly what I have...and wheels very, very close ...with an ET difference of only 2 both front and back that a couple of mm spacer would compensate for?
Even that surprise me because I've just been into the garage to look at the Z4M and visually at least (and it maybe as a result of the curvature of the spokes of the wheels themselves) but the wheels completely fill the width of the car at the front and I wouldn't want them to stick out more. Or does Offset work the other way round i.e. would a higher Offset figure make the wheels more 'inset' into the wheel-arches, if you see what I mean? Like a narrower track?
Thanks!
Thanks!
Wanted 224s or CSLs
Yes - A higher offset ET number will mean the centreline of the wheel is set further IN to the car. Lower offset numbers push the wheels out which is why there is a limit before rubbing starts to become an issue, particularly on the front wheels at the outer edge as the steering is turned.
The hubs are set further in on Z4Ms, so the standard 18" wheels have lower offsets than non M cars.
Chris
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
