I'm not a million miles away from having to replace my tyres so would like to know if run flats are OK on the G29.
Has anyone fitted run flats? Are they 'recommended' by BMW?
Run flats
- Ole gits rule
Run flats
I thought run flats were standard?
M4 Vert in Yas Marina Blue
- raven
Run flats
I had run flats on my 4 Gran Coupe, the road noise was horrible.
The Z4 generates less road noise compared to the gran coupe, I get a little more noise from other vehicles now (not that much), but its less annoying then the sound of run flat tires
I feel like run flat tires are also a lot harder compared to normal tires, not that it bothered me that much, but the difference now is very noticeable even with the harder suspension the shock absorption seems a lot better
I also only had one flat tire in my life (I will most likely get 4 flat tires tomorrow now). So the discomfort is not worth it to me. If I do get a flat tire there's BMW assistance.
I also think if you want to go from non run flat to run flat tires you have to change the rims.
2019 BMW Z4 G29 M40i @600hp - IG: ZZZZ_M40i
- Argyll Andy
Run flats
Not on G29’s all cars run Michelin’s with a tyre repair kit
Actually states run flats can’t be used on standard rims
- CD7A5F27-8B3C-4B66-91ED-EF05FA1F1BA0.png (503.95 KiB) Viewed 546 times
G29 M40i Thundernight with Ivory interior, all option packs (here for a while, hopefully )
E89 23i sDrive, Silver (Gone)
- Ole gits rule
Run flats
that explains it - run flats not on the G29 which is great if I ever buy oneArgyll Andy wrote: ↑Tue May 18, 2021 8:17 pmNot on G29’s all cars run Michelin’s with a tyre repair kit
