LED puddle lights
- N4LLY
LED puddle lights
I fitted them to my E89. Nice and bright.
- 20191116_233405.jpg (103.58 KiB) Viewed 905 times
- Marcusbimmer
LED puddle lights
X6 M50i
Z4 M40i
Z4 M40i
LED puddle lights
raven wrote: ↑Sun May 02, 2021 4:26 pmthen they probably ordered the wrong ones , you have 68 and 50mm ones the 50mm is for the Z4.Marcusbimmer wrote: ↑Sat May 01, 2021 11:33 pmTook delivery today of the Z4. They tried to pop in the BMW-brand lights and they don’t fit this model. Apparently BMW doesn’t make them for this car.raven wrote: ↑Sat May 01, 2021 8:43 am BMW sells them as well, a bit more expensiver probably, but they come with only a few logos, so i didn't buy it i wanted my company's logo in it.
I believe you can just pop them out and disconnect them then pop the other ones in, you need to have a light already at the bottom of your door (not sure if all G29s have this).
https://bmwshop.ekris.nl/nl/accessoires ... -50-mm-bmw
Product number: 63312463924
140euro
Marcus those ones from ECS seem to be the 68mm ones. Raven said it had to be the 50mm ones. Just make sure you can get a refund in case they don't fitMarcusbimmer wrote: ↑Tue May 04, 2021 1:27 pm I hope these fit:
https://www.ecstuning.com/b-genuine-bmw ... 312468386/
- PaperSniper
LED puddle lights
What he said, yes!
2020 BMW Z4 M40i
Misano Blue, Premium, Leather
Need more curves in west Tennessee!
LED puddle lights
Ok so for whatever reason online it doesn’t list the actual LED projectors for the Z4 M40i. This is an error in the system where it believes the vehicle doesn’t have extended light package, which it does. This was confirmed by Cotswold BMW when I ordered.
There are a number of different projectors so be careful to order the correct one. You need part number: 63312463924
They’re super easy to fit, took less than five minutes. Just need a trim removal tool to click the old ones out and then it’s simple plug and play, after picking which projected lens you want.
Instagram @Zed4_M40i
2020 to 2021 - BMW G29 Z4 M40i
2017 to 2020 - BMW F21 M140i
2016 to 2017 - BMW E89 Z4 35i S
2015 to 2016 - BMW F20 M135i
2013 to 2015 - BMW E82 123d M Sport Coupe
2007 to 2011 - BMW E85 Z4 2.5i Sport
LED puddle lights
They do make them, it’s part 63312463924
There is an error on the BMW system saying they’re not available for the G29, but they are a perfect fit
LED puddle lights
Five minute job, plug and play, couldn’t have been simpler.
Took longer for me to decide which slide to use
Like with most things, buy cheap and you’ll buy twice. The BMW projector is more expensive yes, but it’s a perfect fit, the colours are vivid and bright.
Marcusbimmer wrote: ↑Fri Apr 30, 2021 12:23 am How did you go about installing them? Was it a pain in the butt?
- Rucky
LED puddle lights
are they like this in which case the lens just slips out
04 2.5i Titan silver - 1st Z4 now sold on
07 3.0si Silver Grey M Sport pak.
X5 and assorted motorbikes
LED puddle lights
Similar yes but a totally different design to the one pictured, particularly with the way the slide is now encapsulated between two pieces.
Wish I’d taken photos before fitting now
- Rucky
LED puddle lights
his one then - similar idea I guess
LED puddle lights
Similar but still not the same as the new projector. I’ll try and find a picture
LED puddle lights
This is the exact projector for use in the G29
- raven
LED puddle lights
is there anyone who fitted custom slides in their projector thingy? if yes, where did you get them?
2019 BMW Z4 G29 M40i @600hp - IG: ZZZZ_M40i
- raven
LED puddle lights
I got mine installed at BMW today no problems fitting them at all, took about 5 minutes
LED puddle lights
I got mine fitted. Not sure they fitted them right as it’s not a perfect circle. How do you change the slides. You can twist the lens out, but I can see where they put the slide.
